fuel starvation problem while doing a high angle of attack,
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Zenith750-List
roger(at)nwtradingpost.co
PostPosted: Fri Dec 05, 2014 10:01 am    Post subject: fuel starvation problem while doing a high angle of attack, Reply with quote
Jin
As a Zenith 750 builder in an advanced stage of construction let me say thanks for your heads up on this issue
I can understand gravity flow stopping when the carb level rises above the fuel tank outlet level, but assuming that the 0-200 engine installation has a mechanical fuel pump, my question is why the electric fuel pump worked when the mechanical fuel pump didn’t.
Would be interesting to find out also the location of the electrical fuel pump?
I can still make changes!
Roger Venables
From: owner-zenith750-list-server(at)matronics.com [mailto:owner-zenith750-list-server(at)matronics.com] On Behalf Of Jim Kress
Sent: Friday, December 05, 2014 7:50 AM
To: zenith750-list(at)matronics.com
Subject: fuel starvation problem while doing a high angle of attack, power on stall
On a training flight yesterday in a Zenith STOL 750 with an 0-200 engine we experienced a short stoppage of the engine while doing a prolonged high angle of attack, power on stall. We had about half tanks of fuel on board. Once the engine quit we lowered the nose and immediately turned on the electric fuel pump. The engine came back to life and the rest of the flight was uneventful. This phenomenon was not experienced during the 40 hour flight testing period.
There is a placard advising that the "electric boost pump should be used for takeoff and landing", however perhaps this should be changed to say, " electric boost pump should be used during training maneuvers and low level operations" or something like that.
Jim Kress CFII
- The Matronics Zenith750-List Email Forum -
http://www.matronics.com/Navigator?Zenith750-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Zenith750-List All times are GMT - 8 Hours
