digidocs
Posted: Mon Dec 22, 2014 10:49 am Post subject: SD8 output at 28V? |
Hello Aeroelectric,
Does anyone have information about the SD8 output performance at 28V?
B&C are advertising a 28V version, but were unable to provide any data when I asked.
I also took Bob's 12.5V/13.8V output ratings at 3100 alternator RPM and built a Thevenin equivalent circuit. That shows open circuit voltage of only ~20V. Hopefully that's not an accurate way to model this device.
David
Posted: Mon Dec 22, 2014 1:37 pm Post subject: SD8 output at 28V? |
At 12:49 2014-12-22, you wrote:
Hello Aeroelectric,
data when I asked.
this device.
David
Both 14 and 28v versions are wound by B&C. The
28v version would have more turns on it than
the 14v. The alternator's output is roughly
limited by the magnetics. This is a 100W alternator
frame so I would imagine that the 28v performance
for current is 1/2 that of the 14v version.
I'll be at B&C in then next few weeks . . .I'll
check for sure.
digidocs
Posted: Mon Dec 22, 2014 1:52 pm Post subject: Re: SD8 output at 28V? |
Bob,
That's really helpful information. I currently have the 14V version and B&C told me that I could switch it to 28V by simply changing the regulator. It sounds like that may not be the case. (no pun intended)
David
Posted: Tue Dec 23, 2014 6:32 am Post subject: SD8 output at 28V? |
At 15:52 2014-12-22, you wrote:
Bob,
Hmmmm . . . I am surprised at that. I'll explore
it further. I was involved in the SD-8 development
wasssyyyy back when . . . in fact, that alternator
was designed and produced at the request of Burt
Rutan to Bill Bainbridge. Burt was alarmed at the
heavy systems being installed on his designs and
he was hoping that B&C could rise to the challenge
of offering a 'tiny' system to run a few radios
for day/vfr operations.
The SD-8 and it's belt driven cousins were the
outcome of Bill's response to Burt . . . and it
put B&C on the fledgling OBAM aircraft industry's
map.
We worked with several combinations of wire size
and turns on a 'stock' garden tractor alternator
to optimize performance at pedestrian vacuum-pump
pad speeds. That was about 1982-84 and I've not had
any hands-on with that system since . . . therefore
not familiar with interim changes or the current
design philosophy. I'll find out.
