rparigoris
Posted: Sun Dec 21, 2014 5:44 pm Post subject: Using a digital scale for measuring Epoxy |
Hi Group
I just want to make a quick comment on using a Digital scale to measure Epoxy:
Don't absolute put trust in them without verification!
I have a few scales, and sometimes they get out of calibration when pouring Epoxy or Hardener slowly.
I'm not talking about an absolute calibration with a standard (which I do once in a while), I'm talking about the "zero" calibration changing during weighing.
What I do prior to mix, I make sure I have "two" empty mixing cups (with mixing sticks) that weigh exactly the same.
I then zero out a cup with mixing stick.
Then pour Epoxy, switch cups to make sure still zeroed. If not than rezero and make Epoxy adjustment.
Then add Hardener, switch cups to make sure still zeroed. If not then rezero and make Epoxy adjustment.
Mixing stick is absolutely needed for Redux mix, I find it helpful if you overdid Aeropoxy Epoxy.
My two cents.
Ron Parigoris
budyerly(at)msn.com Guest
Posted: Mon Dec 22, 2014 8:19 am Post subject: Using a digital scale for measuring Epoxy |
Ron and others,
No doubt about it. Calibrate your electric scale and check often.
I have an old triple beam (like in chemistry class years ago, yea, I can
still use a slide rule too) and I calibrate it at least once a month due to
client drips and required gummy clean ups. I use the squeeze bottles from
Aircraft spruce for the resin and hardener (throw away after a year) and we
still get messy.
I don't have much use for the pumps, but if you are doing a Classic wing or
Long Eze from scratch in mid summer, they work great for the couple of weeks
you need one. Then they need a complete clean out.
My two cents thrown on too.
Bud Yerly
Sent: Sunday, December 21, 2014 8:44 PM
To: <europa-list(at)matronics.com>
Subject: Using a digital scale for measuring Epoxy
<rparigor(at)suffolk.lib.ny.us>
Hi Group
Epoxy:
weighing.
My two cents.
Ron Parigoris
http://forums.matronics.com/viewtopic.php?p=435985#435985
