No carburetor heat...
jbsoar(at)gmail.com
PostPosted: Sun Mar 13, 2016 4:47 am    Post subject: No carburetor heat... Reply with quote
Fellow Listers:Has anyone experienced carburetor ice while flying a Yak, and how was the situation resolved?  Is carburetor ice a common problem with M14-P engines?
John B
TigerAirshows
PostPosted: Mon Mar 14, 2016 7:49 am    Post subject: Re: No carburetor heat... Reply with quote
Yes. Very common in High humidity environments. Especially during cross country. Make sure your aircraft is configured for the condition of flight you plan to encounter.
Attached are photos fright from the Tech description manual of the Yak 55.
 Filesize:  895.01 KB
 Viewed:  4492 Time(s)
 Filesize:  1.35 MB
 Filesize:  1.42 MB
 Filesize:  1.54 MB
Carb Inlet Pipe
 Filesize:  1.29 MB
 Filesize:  1.29 MB
Mark Sorenson-
www.tigerairshows.com
Looigi
PostPosted: Tue Mar 15, 2016 12:44 pm    Post subject: Re: No carburetor heat... Reply with quote
Hello there,
Slightly different topic, but where could I get a copy of that cool book?
Cheers
Chris
