Rick Moss
Posted: Mon Jul 20, 2015 4:06 am Post subject: Looking for an airmaster AC200 controller |
Hi all,
My Airmaster AC200 controller is generating loads of RF noise and I'm struggling to get my laptop to communicate with it for the firmware update that supposedly resolves that issue!
Does anybody have a spare unit that they would like to sell?
Many thanks,
Rick
G-OGAN
rampil
Posted: Mon Jul 20, 2015 7:46 am Post subject: Re: Looking for an airmaster AC200 controller |
It might well be easier and cheaper to fix your comm problem. If you describe the problem in sufficient detail, it is possible someone here can help.
Details must include the type of computer, operating system and revision level,
exact details of the error messages if any, etc.
Rick Moss
Posted: Mon Jul 20, 2015 8:06 am Post subject: Re: Looking for an airmaster AC200 controller |
I shall try:
No error message, just no connection detected by the software.
I'm using a Windows Surface pro 3 running Windows 8.1.
The usb>serial adaptor is recognised by the control panel and shows as functional.
Whether set on the PC to COM1 or 2 (the only ports the airmaster software recognises) then it does not acknowledge the connection.
This is being done in the aircraft with the power to the AC200 connected and the connection lead plugged into the only port it will fit into. The other connections on the AC200 are still connected.
Ideas gratefully received!
cptimm29(at)gmail.com Guest
Posted: Mon Jul 20, 2015 11:49 am Post subject: Looking for an airmaster AC200 controller |
Hello Rick,
I have such a unit , but I am located in British Columbia, Canada. Should you have no luck with the re-programming, we could work out a deal.
I have no use for it, as I have gone back to the ground adjustable Warp Drive prop. My Europa will be advertised for sale shortly also.
Cheers, Peter Timm
On 2015-07-20, at 9:06 AM, Rick Moss wrote:
I shall try:
http://forums.matronics.com/viewtopic.php?p=444978#444978
Rick Moss
Posted: Mon Jul 20, 2015 12:34 pm Post subject: Re: Looking for an airmaster AC200 controller |
Hi Peter,
Can you drop me a line to rkwmoss(a)gmail.com with a price and which version it is?
Rick
Rick Moss
Posted: Wed Jul 22, 2015 8:50 am Post subject: Re: Looking for an airmaster AC200 controller |
I took my existing controller home, and was able to update it using my desktop (as opposed to my laptop and a USB>Serial adapter). Will refit it soon and hopefully but interference issues will be gone....
Thanks all
