				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| wdaniell.longport(at)gmai Guest
				|  Posted: Sun Jan 11, 2015 3:43 pm    Post subject: Stern post and ribs |   |
				| A question for the assembled wisdom.
The port side of the stern post has to be cut back as does the outer skin.  As I understand it the stern post on the port side glues to the foam.
 From the manual it appears that one should glue first and then cut back....but it looks easier to cut first and then glue.
 Any thoughts?
 Will
 William Daniell
 LONGPORT
 +57 310 295 0744
 | |  |  | - The Matronics Europa-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Europa-List
		| Back to top |  |
		| jglazener
				|  Posted: Mon Jan 12, 2015 7:34 am    Post subject: Re: Stern post and ribs |   |
				| William,
 Have a look at:
 http://europaowners.org/main.php?g2_itemId=100716
 Would be happy to provide further details, on or offline.
 Regards, Jeroen
 Jeroen
 http://www.europaowners.org/main.php?g2_itemId=44165
		| Back to top |  |
				|  Posted: Mon Jan 12, 2015 7:48 am    Post subject: Stern post and ribs |   |
				| Thanks
that helps.  I see you cut back the port side and then bonded which was my concern (as opposed to bonding and then cutting back.
 thanks again
 Willl
 William Daniell
 LONGPORT
 +57 310 295 0744
 On Mon, Jan 12, 2015 at 10:34 AM, jglazener <j.glazener(at)planet.nl (j.glazener(at)planet.nl)> wrote:
 [quote]--> Europa-List message posted by: "jglazener" <j.glazener(at)planet.nl (j.glazener(at)planet.nl)>
 William,
 Have a look at:
 Regards, Jeroen
 Jeroen
 http://forums.matronics.com/viewtopic.php?p=436883#436883
 br> fts!)
 r> > com" target="_blank">www.aeroelectric.com
 w.buildersbooks.com" target="_blank">www.buildersbooks.com
 p.com" target="_blank">www.homebuilthelp.com
 e.com" target="_blank">www.mypilotstore.com
 " target="_blank">www.mrrace.com
 pa-List" target="_blank">http://www.matronics.com/Navigator?Europa-List
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
