Ignition Switch
BobbyPaulk(at)comcast.net
PostPosted: Sat Jan 17, 2015 5:59 am    Post subject: Ignition Switch Reply with quote
List
I was trying to use the ACS Ignition switch so that I would not have a gaping hole in the center of the panel.
I will use two toggle switches with a guard to keep from inadvertently shutting them down.
Thanks for the responses.
bobby
BARRY CHECK 6
PostPosted: Sat Jan 17, 2015 8:22 am    Post subject: Ignition Switch Reply with quote
Bobby:
A suggestion:
Do NOT use a guard.  The guard I am referring to is the type that when pushed down turns the switches to OFF.  The guard that works very well is a simple U on both sides of the switch sort of like this (!),  They work very well, as long as the height is ABOVE that of the switch.  Another type of switch would be on the order of a Landing Gear Retract Switch...  It requires a PULL OUT so the switch can be moved from one position to the other.
Barry
On Sat, Jan 17, 2015 at 8:59 AM, <BobbyPaulk(at)comcast.net (BobbyPaulk(at)comcast.net)> wrote:
[quote]List
bobby
_blank">www.aeroelectric.com
.com" target="_blank">www.buildersbooks.com
="_blank">www.homebuilthelp.com
="_blank">www.mypilotstore.com
ank">www.mrrace.com
ist" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-List
tp://forums.matronics.com
