BobbyPaulk(at)comcast.net Guest
Posted: Wed Jan 21, 2015 3:42 pm Post subject: Switch guards |
Rob
Thanks for the warning but I never intended to start my engine by propping it since the ignition does not have a retard position. My engine has never started when the weather was below 60 degrees. The battery would have to be stoned to not turn the engine over at all. Also I am putting in a jumper connection that can be used without pulling the cowl.
Also the "Guard" for the mag switches I intend to use is more like a side shield.
I plan to fabricate them from aluminum but they will serve the same purpose as these:
http://www.steinair.com/storedetail.cfm?productid=556
Thanks again for all your inputs.
I really get a lot out of the tips and advice.
bobby
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
