BobbyPaulk(at)comcast.net Guest
Posted: Sat Jan 17, 2015 6:07 am Post subject: Mag |
Rob
The E-mag I am going to be using is made by Rotec in Australia.
It uses about 3.5 amps at cruise RPM's.
The Jabiru Mags need about 300 RPM to fire so if your battery is weak, oil is cold and thick, and the fuel doesn't want to vaporize it makes for a bad morning. We are only talking about 55 to 65 degrees. The Rotec mag will allow propping the engine so it's a win win situation.
Bobby
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
matronics(at)rtist.nl Guest
Posted: Sat Jan 17, 2015 12:51 pm Post subject: Mag |
Bobby,
The Rotec mag will *not* allow you to hand prop the engine, and in fact it would be downright dangerous to try. The ignition is fixed at 20 degrees BTDC, an attempt to hand prop would cause a kickback and might take your fingers. I know Paul from Rotec advertizes that it can be done, I dare him to put his attempt on Youtube.
Rob
On 1/17/2015 3:06 PM, BobbyPaulk(at)comcast.net (BobbyPaulk(at)comcast.net) wrote:
[quote] Rob
Bobby
