Conversion from Monowheel to Nosewheel or Tailwheel Underca
rlborger(at)mac.com
PostPosted: Fri Jan 23, 2015 10:16 am    Post subject: Conversion from Monowheel to Nosewheel or Tailwheel Underca Reply with quote
Howard & George,
If you are curious as to what is involved in the conversion to tri-gear, I suggest you check out my build site on europaowners.org as there is an album showing what I went through to convert from mono-wheel to tri-gear.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs).
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
On Jan 23, 2015, at 10:25 AM, George Nielsen <genie(at)swissmail.org> wrote:
This is a subject in which I am also interested. Therefore I took the liberty of changing the subject to something more meaningful, as I may keep a few replies. (If that is not OK with the sender please let me know.)
George Nielsen
On 23/01/2015 09:02, Europa-List Digest Server wrote:
Time: 06:53:23 PM PST US
Subject: looking for.....
.someone who had intended to make either a trigear conversion or a conventional
conversion from a mono wheel to either. Id like to purchase a kit if anyone
knows of, or has one for sale Thanks, Howard
phillik747
PostPosted: Fri Jan 23, 2015 10:41 am    Post subject: Conversion from Monowheel to Nosewheel or Tailwheel Underca Reply with quote
I too have been in the process of changing from a mono wheel to a tri gear.  I have images of the process on europaowners.org under "Kyles Europa."
I'm located in Alabama if you're nearby.
Bob's images helped me a lot when starting the process.
Kyle [quote][b]
Kyle
Europa Tri-gear (under construction)
