spcialeffects
Posted: Thu Feb 26, 2015 3:59 am Post subject: Low Flap |
Hi all. I have rigged my plane and have noticed that the port flap hangs low by 3 to 4mm when put into the up position. If i grab the flap i can move it up the few millimeters I'm trying to remove. This gap happens with or without the outriggers fitted. I also have Fred K's enhanced fairings fitted. I have read the hits and tips book supplied by the club and there is one account and solution mentioned in it but i thought i would post on here to see if any other people have experienced this problem. I am building a mono but suspect this may happen to a tri gear build as well, as i think the problem originates due to the fact that the connecting rod is attached to the flap cross tube on the STBD side which will always pull that side tighter. Any suggestions are very welcome. Many thanks Frank
