Ernie
Posted: Thu Mar 12, 2015 2:16 pm Post subject: Main Air Tank |
Here are pics of the tank I fashioned for my plane.
Specs:
Drager 4500 PSI 60 min Carbon Fiber Wrapped Aluminum Tank.
Weight 10 lbs
Length 21"
Diameter 7"
Hydro Tested to 7500 PSI.
Fittings:
Stainless Steel SCBA to NPT Adapter
NPT to AN #4 Male Adapter.
This should fit in the same bracket where the stock tanks lives. All thats left is to create an aluminum tube pigtail with an AN B-Nut on one end and the Chinese Nut on the other.
[img]cid:ii_14c100d2fd57eeb6[/img][img]cid:ii_14c100d55d2f94fa[/img]
| Description: |
| Filesize: |
667.3 KB |
| Viewed: |
5698 Time(s) |
| Description: |
| Filesize: |
669.83 KB |
| Viewed: |
5698 Time(s) |
hkgibby(at)yahoo.com Guest
Posted: Thu Mar 12, 2015 3:11 pm Post subject: Main Air Tank |
Ernie-
Jax Fluid Technologies 904-642-2093 is a nearby source for Swagelok tubing/ferrules/valves that might help you finish things off. You should do a Red Star article when all done with your setup...looks good. Keep us posted.
Hoot
| Quote: | On Mar 12, 2015, at 6:15 PM, Ernest Martinez <erniel29(at)gmail.com> wrote:
Specs:
Weight 10 lbs
Length 21"
Diameter 7"
Fittings:
<IMG_0095_2.jpg><IMG_0096_2.jpg>
samira.h(at)shaw.ca Guest
Posted: Thu Mar 12, 2015 4:08 pm Post subject: Main Air Tank |
Hi Ernie,
Sir - you are a genius, thank you so much for your posting.
Please don't get discouraged by some others, your solution
is plain great.
Thank you again.
Blue Skies and Happy Landings.
cheers
Elmar
Dawg
Posted: Thu Mar 12, 2015 6:43 pm Post subject: Main Air Tank |
good job Ernie.
On Mar 13, 2015, at 7:15 AM, Ernest Martinez <erniel29(at)gmail.com> wrote:
| Quote: | Here are pics of the tank I fashioned for my plane.
Specs:
Weight 10 lbs
Length 21"
Diameter 7"
Fittings:
_________________ Dawg |
cd001633(at)mindspring.co Guest
Posted: Thu Mar 12, 2015 8:59 pm Post subject: Main Air Tank |
Ernie,
Would a Drain port be needed here as in the original tank for draining moisture/water?
Sam
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Ernest Martinez
Sent: Thursday, March 12, 2015 6:15 PM
To: yak-list
Subject: Main Air Tank
Specs:
Weight 10 lbs
Length 21"
Diameter 7"
Fittings:
| Description: |
| Filesize: |
31.93 KB |
| Viewed: |
5682 Time(s) |
| Description: |
| Filesize: |
29.42 KB |
| Viewed: |
5682 Time(s) |
Dawg
Posted: Fri Mar 13, 2015 2:17 am Post subject: Main Air Tank |
Air dryer filter as on airlines for paint gun? Cheap and easy before bottle.
Sent from my iPad
On Mar 13, 2015, at 13:58, Sam Sax <cd001633(at)mindspring.com (cd001633(at)mindspring.com)> wrote:
| Quote: | v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> <![endif]-->
Ernie,
Sam
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] On Behalf Of Ernest Martinez
To: yak-list
Specs:
Weight 10 lbs
Length 21"
Diameter 7"
Fittings:
<image002.jpg><image004.jpg>
| [quote][b]
Dawg
Posted: Fri Mar 13, 2015 2:21 am Post subject: Main Air Tank |
Don't just have one machined. Have a couple just in case. (In case I need one!)
Sent from my iPad
| Quote: | On Mar 13, 2015, at 07:15, Ernest Martinez <erniel29(at)gmail.com> wrote:
Specs:
Weight 10 lbs
Length 21"
Diameter 7"
Fittings:
Ernie
Posted: Fri Mar 13, 2015 3:44 am Post subject: Main Air Tank |
Sam,
Good question. Unfortunately High Pressure tanks have to be seamless so a drain port is not a possibility. This is why it's important to keep your air dryer serviced. But since it's aluminum rust isn't an issue. Would have to make it part of the annual service routine to remove and dump.
Ernie
On Fri, Mar 13, 2015 at 12:58 AM, Sam Sax <cd001633(at)mindspring.com (cd001633(at)mindspring.com)> wrote:
Ernie,
Sam
To: yak-list
Specs:
Weight 10 lbs
Length 21"
Diameter 7"
Fittings:
| Description: |
| Filesize: |
31.93 KB |
| Viewed: |
5679 Time(s) |
| Description: |
| Filesize: |
29.42 KB |
| Viewed: |
5679 Time(s) |
Ernie
Posted: Fri Mar 13, 2015 4:23 am Post subject: Main Air Tank |
Bill,
I didn't machine it, you can buy the adapter on Ebay for $35.
Ernie
On Fri, Mar 13, 2015 at 6:20 AM, Bill Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote:
[quote]--> Yak-List message posted by: Bill Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)>
Sent from my iPad
> On Mar 13, 2015, at 07:15, Ernest Martinez <erniel29(at)gmail.com (erniel29(at)gmail.com)> wrote:
> Specs:
> Weight 10 lbs
> Length 21"
> Diameter 7"
> Fittings:
List" target="_blank">http://www.matronics.com/Navigator?Yak-List
FORUMS -
b Site -
-Matt Dralle, List Admin.
kelmonroe(at)comcast.net Guest
Posted: Fri Mar 13, 2015 4:28 am Post subject: Main Air Tank |
Has anyone had work done at Eagle Works Aviation/Dan Payne in Hixon
Tennessee?
Thanks Kelley Monroe
Viperdoc
Posted: Fri Mar 13, 2015 5:16 am Post subject: Main Air Tank |
What is the lone pressure from the compressor to the tank?
Doc
Sent from my iPad
On Mar 13, 2015, at 5:16 AM, Bill Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote:
[quote]Air dryer filter as on airlines for paint gun? Cheap and easy before bottle.
Sent from my iPad
Ernie,
Sam
To: yak-list
Specs:
Weight 10 lbs
Length 21"
Diameter 7"
Fittings:
ist"">http://www.matronics.com/Navigator?Yak-List
//forums.matronics.com
_________________ Viperdoc |
Ernie
Posted: Fri Mar 13, 2015 5:24 am Post subject: Main Air Tank |
Not quite sure I understand your question. Are you referring to the main air tank or the emergency tank scenario I illustrated?
Nothing changes WRT to the main air tank mod. Its just a simple replacement. The air pressure in the tank would be whatever you have your pressure relief valve set to, generally 50 bar or about 750 PSI.
With the emergency tank, there is no input to the emergency bottle. It is standalone with just output to the emergency circuit. The pressure in the bottle is 4500 PSI, regulated down to 800 PSI.
Ernie
On Fri, Mar 13, 2015 at 9:15 AM, Roger Kemp <f16viperdoc(at)me.com (f16viperdoc(at)me.com)> wrote:
[quote]What is the lone pressure from the compressor to the tank?
Doc
Sent from my iPad
| Quote: | Air dryer filter as on airlines for paint gun? Cheap and easy before bottle.
Sent from my iPad
Ernie,
Sam
To: yak-list
Specs:
Weight 10 lbs
Length 21"
Diameter 7"
Fittings:
tp://forums.matronics.com
Posted: Fri Mar 13, 2015 10:28 am Post subject: Main Air Tank |
Another difference between the YAK-50 and YAK-52 original design.
On the 52, the emergency bottle is only filled via the aircrafts external fill port. Main bottle is filled by either the external fill port, or the engine compressor.
On the YAK-50, both bottles are filled by the engine compressor or the external fill port.
Not sure why they were designed differently, but that said the 52 emergency bottle is a one shot kind of thing, once it empty, it's empty. On the 50, you can close it, wait for it to pump up in-flight and try it again.
Mark
rocknpilot(at)hotmail.com Guest
Posted: Fri Mar 13, 2015 10:48 am Post subject: Main Air Tank |
Mark,
Does the 50 also have shuttle valves?
Rico Jaeger
915 S. 11th Ave.
Wausau, WI. 54401
715.529.7426
1966 Cessna 150F ^/---//-X
N8558G //Hangar #35 / AUW
1992 Yakovlev Yak 52^/---//-X
N21YK //
Hangar #21 / AUW
[quote] From: mark.bitterlich(at)navy.mil
To: yak-list(at)matronics.com
Subject: RE: Main Air Tank
Date: Fri, 13 Mar 2015 18:27:59 +0000
--> Yak-List message posted by: "Bitterlich, Mark G CIV NAVAIR, WD" <mark.bitterlich(at)navy.mil>
Mark
Posted: Fri Mar 13, 2015 6:00 pm Post subject: Main Air Tank |
Yes, it does.
Mark
From: owner-yak-list-server(at)matronics.com [owner-yak-list-server(at)matronics.com] on behalf of Rico Jaeger [rocknpilot(at)hotmail.com]
Sent: Friday, March 13, 2015 2:48 PM
Mark,
Rico Jaeger
915 S. 11th Ave.
Wausau, WI. 54401
715.529.7426
N8558G //
Hangar #35 / AUW
1992 Yakovlev Yak 52 ^/---//-X
N21YK //
Hangar #21 / AUW
Mark
wlannon(at)shaw.ca Guest
Posted: Sat Mar 14, 2015 7:23 pm Post subject: Main Air Tank |
Ernie;
“Since it’s aluminum rust isn’t an issue”. That may be the case but only if it is pure aluminum which is protected from corrosion by it’s own oxide layer. If it is an alloy that protection is seriously degraded depending on the alloy composition and strength.
Pure aluminum has a strength something like cheddar cheese. However if the entire strength of the tank is derived from the carbon fibre wrapping then pure aluminum would be suitable.
Something to consider.
Walt
Sent: Friday, March 13, 2015 4:36 AM
To: yak-list (yak-list(at)matronics.com)
Subject: Re: Main Air Tank
Sam,
Ernie
Ernie,
Sam
To: yak-list
Specs:
Weight 10 lbs
Length 21"
Diameter 7"
Fittings:
[img]cid:3E1306D8CD464D6AB7151734EBAA121F(at)WalterHP[/img][img]cid:BECBC68057F24B84ABA24AB021F4B313(at)WalterHP[/img]
| Description: |
| Filesize: |
31.93 KB |
| Viewed: |
5638 Time(s) |
| Description: |
| Filesize: |
29.42 KB |
| Viewed: |
5638 Time(s) |
Viperdoc
Posted: Sat Mar 14, 2015 9:16 pm Post subject: Main Air Tank |
Line pressure from the compressor before entering the pop- off valve. Miss typed the word line. Came over as lone.
Sorry poor proof reading,
Doc
Sent from my iPad
On Mar 13, 2015, at 8:23 AM, Ernest Martinez <erniel29(at)gmail.com (erniel29(at)gmail.com)> wrote:
[quote]Not quite sure I understand your question. Are you referring to the main air tank or the emergency tank scenario I illustrated?
Ernie
| Quote: | What is the lone pressure from the compressor to the tank?
Doc
Sent from my iPad
Sent from my iPad
Ernie,
Sam
To: yak-list
Specs:
Weight 10 lbs
Length 21"
Diameter 7"
Fittings:
Ernie
Posted: Sun Mar 15, 2015 6:18 am Post subject: Main Air Tank |
Yep you're correct, if it's not the right alloy, it could be a problem. Fortunately these things are strictly regulated. The aluminum tanks by themselves are rated for 2260 PSI, the Carbon Fiber brought them up to 4500 PSI. Again, at the pressures I'm going to run it at, its not an issue at all. Also remember aluminum scuba tanks are made of the same stuff and live in salt water all their lives. At the end of the day it's all about diligent maintenance.
The reason I'm doing this because I'm terrified of my current 40 yr old steel welded tank, that I have no reliable history on, and can't get hydrotested locally. Yes I know there is some place I can ship it to, but I have several issues with that. I'd rather be able to do it locally and have it back the next day. And I like the fact that it's tested to known parameters (7500 PSI), and a guy is willing to put his name on it and certify it.
But since it doesn't fit where the original tank goes I've given my self a good reason to mount it where it will be VERY easy to remove The stock tanks lives under my smoke system and Battery box, shelf and I'm going to have to remove everything to get the bottle out.
Ernie
On Sun, Mar 15, 2015 at 1:14 AM, Roger Kemp <f16viperdoc(at)me.com (f16viperdoc(at)me.com)> wrote:
[quote]Line pressure from the compressor before entering the pop- off valve. Miss typed the word line. Came over as lone.
Doc
Sent from my iPad
| Quote: | Not quite sure I understand your question. Are you referring to the main air tank or the emergency tank scenario I illustrated?
Ernie
Doc
Sent from my iPad
Sent from my iPad
Ernie,
Sam
To: yak-list
Specs:
Weight 10 lbs
Length 21"
Diameter 7"
Fittings:
