Herbgh(at)nctc.com Guest
t41pilot
Joined: 05 Sep 2011 Posts: 38 Location: Howard City, Michigan
Posted: Mon Mar 23, 2015 12:02 pm Post subject: Re: Auto Pilot for less than 100 bucks... |
Back when I was building my firefly, I thought of installing electric trim for an elevator tab. I did some research on RC servos and wind loads. I took worst case scenarios for a trim tab at 90 degrees to the airflow and found that sail winch servos for boats had more than enough torque to do the job. I came up with a circuit using a 555 timer and a bargraph to show position of the trim tab (assuming no mechanical failure of the linkage). I never installed the system though so have no actual flight data but in theory it could work. Arduino already has sketches for servos and 10dof sensors since robots have become so prolific, so I'm sure if you put your mind to it, it could be done. I have used arduino circuits in my plane in other capacities such as strobe lights and capacitive fuel indicator with a bargraph. I'm just installing the arduino version fuel indicator now. My analog version worked just fine but I got bored over the winter and had to invent a new one with a larger, brighter display. My circuits for the plane as well as links to my Youtube videos can be found on my web page.
http://myplace.frontier.com/~t41pilot/index.html
_________________ Gregg Kaat
2011 Firefly |
