byoungplumbing(at)gmail.c Guest
Posted: Sat Apr 11, 2015 6:14 am Post subject: Kolb-List Digest: 3 Mgs - 04/10/15 |
I had my battery up front in my mk III for a while then moved it back...
it just seemed to fly better with the cg back.... especially with a
passenger.
boyd
Well John, that does make sense. I live just about 50 airmiles South of your
unintended
landing at the falls. I think I will install them as they are. I fly
off a 2000' grass strip and PLAN on any off field landings. Has anyone moved
the
battery to the nose section of the plane? I know that is a long way to run
the positive cable but It sure would help with the CG.
Bob
http://www.avast.com
rowedenny
Posted: Sat Apr 11, 2015 6:31 am Post subject: Kolb-List Digest: 3 Mgs - 04/10/15 |
If John H has a huge tail wheel, 26 gallon of fuel, and a 912S with a three blade 72" warp drive prop all behind his C/G, and his scrawny little butt in front of the C/G and doesn't need his battery in the nose to balance his Mark3, why does any Mark3 need nose ballast?
Dennis "Skid" Rowe
Mk3, Rotax 670,
Leechburg, PA
| Quote: | On Apr 11, 2015, at 10:12 AM, b young <byoungplumbing(at)gmail.com> wrote:
I had my battery up front in my mk III for a while then moved it back... it just seemed to fly better with the cg back.... especially with a passenger.
boyd
Well John, that does make sense. I live just about 50 airmiles South of your unintended
off a 2000' grass strip and PLAN on any off field landings. Has anyone moved the
Bob
worrybear(at)verizon.net Guest
Posted: Sat Apr 11, 2015 11:12 am Post subject: Kolb-List Digest: 3 Mgs - 04/10/15 |
I started my Ultrastar out with 3 wieghts in the nose to get it balanced. I
took out 1, it flew great. Took out 2, it flew great. Took out 3, it flew
great. Never gave it another thought.
Dan Walter
Ercoupe
do not archive do we still do this?
