JabiruEngine-List Digest: 2 Msgs - 04/18/15
AirEupora
PostPosted: Sun Apr 19, 2015 6:19 am    Post subject: JabiruEngine-List Digest: 2 Msgs - 04/18/15 Reply with quote
I would not be to concerned with the lower fuel pressure. Temperatures are warner now than in December, so the fluid (fuel) might be thinner. Sounds like you have a MGL or Dynon . What I'd be looking at is the fuel flow to the engine. In December what was the fuel flow per hour. Should be close to 10.5 gallons on take off and climb out. What are your EGT's showing; should be in the 640C range then when you pull power back to the 3/4 position they should go up to 680C.
Rick Stockton
Europa N120EJ
Jabiru 3300
100%
On Sunday, April 19, 2015 12:21 AM, JabiruEngine-List Digest Server <jabiruengine-list(at)matronics.com> wrote:
Today's complete JabiruEngine-List Digest can also be found in either of the
of the JabiruEngine-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2015-04-18&Archive=JabiruEngine
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2015-04-18&Archive=JabiruEngine
� JabiruEngine-List Digest Archive
Total Messages Posted Sat 04/18/15: 2
Today's Message Index:
1. 03:46 PM - Fuel Pressure (BobbyPaulk(at)comcast.net (BobbyPaulk(at)comcast.net))
� 2. 06:11 PM - Re: Fuel Pressure (Gary Aman)
________________________________ Message 1 _____________________________________
Time: 03:46:38 PM PST US
From: BobbyPaulk(at)comcast.net (BobbyPaulk(at)comcast.net)
Subject: Fuel Pressure
List
Today was the first flight on the Jabiru 3300 since my off field landing back in
December ( due to both ignition coils being wiped out ).
I noticed the fuel pressure had dropped from 1.8 ~ 2.1 to 1.4 plus or minus. I
have my low pressure alarm set at 1.8 so I kept getting an alarm unless I kept
the electric boost pump on.
The engine has not been run since the first of December 2014. Question: Should
I be concerned about the 1/2 lb. pressure drop or is it a case of TMI ( too much
information ).
I know of at least two guys that do not even have a fuel pressure gauge.
Anyone have any idea how long the engine driven fuel pump is good for. It has 236
hours on it but it is at least 8 years old.
By the way I noticed my maximum RPM on take off went from 2600 to 2720 just before
rotation speed. I attribute that to the new Rotek E-mag and the newer Honda
ignition coil.
Bobby ( age 76 )
Zodiac 601 XL "B"
Jabiru 3300 S/N 1141
Sensenich 64" x 51" Prop
Bing Carb 260 Main & 290 Needle Jet
Status - Flying 236 hrs.
________________________________ Message 2 _____________________________________
Time: 06:11:33 PM PST US
Subject: Re: Fuel Pressure
From: Gary Aman <zeprep251(at)aol.com (zeprep251(at)aol.com)>
Have 930 hrs on original pump, no pressure gauge, but turning 3100 on take o
ff.
On Apr 18, 2015, at 6:43 PM, BobbyPaulk(at)comcast.net (BobbyPaulk(at)comcast.net) wrote:
List
ack in December ( due to both ignition coils being wiped out ).
s. I have my low pressure alarm set at 1.8 so I kept getting an alarm unless
I kept the electric boost pump on.
ould I be concerned about the 1/2 lb. pressure drop or is it a case of TMI (
too much information ).
as 236 hours on it but it is at least 8 years old.
t before rotation speed. I attribute that to the new Rotek E-mag and the new
er Honda ignition coil.
Bobby ( age 76 )
Zodiac 601 XL "B"
Jabiru� 3300 S/N 1141
3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3
D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
=3D=3D=3D=3D=3D=3D=3D=3D="http://www.matronics.com/Navigator?JabiruEngine-List" target="_blank"orums.matronics.com/" target="_blank">http://forums.matronics.com
; -Matt Dralcontribution" target="_blank">http://www.matronics.com/contribution
BARRY CHECK 6
PostPosted: Wed Apr 29, 2015 1:17 pm    Post subject: JabiruEngine-List Digest: 2 Msgs - 04/18/15 Reply with quote
Rick,
Gas does not THIN...� Gas vaporizes. �
Why are you saying the EGT increases as power is pulled back?
Barry
On Sunday, April 19, 2015, Rick Stockton <aireupora(at)sbcglobal.net (aireupora(at)sbcglobal.net)> wrote:
I�would not be to concerned with the lower fuel pressure.� Temperatures are warner now than in December, so the fluid (fuel) might be thinner.� Sounds like you have a MGL or Dynon .� What I'd be looking at is the fuel flow to the engine.� In December what was the fuel flow per hour.� Should be close to 10.5 gallons on take off and climb out.� What are your EGT's showing; should be in the 640C range then when you pull power back to the 3/4 position they should go up to 680C.
Rick Stockton
Europa N120EJ
Jabiru 3300
100%
On Sunday, April 19, 2015 12:21 AM, JabiruEngine-List Digest Server <[url=javascript:_e(%7B%7D,'cvml','jabiruengine-list(at)matronics.com');]jabiruengine-list(at)matronics.com[/url]> wrote:
� Online Versions of Today's List Digest Archive
two Web Links listed below.� The .html file includes the Digest formatted
and Message Navigation.� The .txt file includes the plain ASCII version
HTML Version:
� � http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2015-04-18&Archive=JabiruEngine
Text Version:
� � http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2015-04-18&Archive=JabiruEngine
� EMail Version of Today's List Digest Archive
� � � � � � � � � � � � � JabiruEngine-List Digest Archive
� � � � � � � � � � Total Messages Posted Sat 04/18/15: 2
� � 1. 03:46 PM - Fuel Pressure� ([url=javascript:_e(%7B%7D,'cvml','BobbyPaulk(at)comcast.net');]BobbyPaulk(at)comcast.net[/url])
� � 2. 06:11 PM - Re: Fuel Pressure� (Gary Aman)
________________________________� Message 1� _____________________________________
From: [url=javascript:_e(%7B%7D,'cvml','BobbyPaulk(at)comcast.net');]BobbyPaulk(at)comcast.net[/url]
Subject: JabiruEngine-List: Fuel Pressure
List
information ).
ignition coil.
Bobby ( age 76 )
Zodiac 601 XL "B"
________________________________� Message 2� _____________________________________
From: Gary Aman <[url=javascript:_e(%7B%7D,'cvml','zeprep251(at)aol.com');]zeprep251(at)aol.com[/url]>
ff.
On Apr 18, 2015, at 6:43 PM, [url=javascript:_e(%7B%7D,'cvml','BobbyPaulk(at)comcast.net');]BobbyPaulk(at)comcast.net[/url] wrote:
List
Bobby� ( age 76 )
Zodiac 601 XL "B"
Jabiru� 3300� S/N� 1141
Status - Flying� 236 hrs.
; � � � � � � � � � -Matt Dralcontribution" target="_blank">http://www.matronics.com/contribution
ist" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-List
Sent from Gmail Mobile
pete(at)usjabiru.com
PostPosted: Wed Apr 29, 2015 1:43 pm    Post subject: JabiruEngine-List Digest: 2 Msgs - 04/18/15 Reply with quote
Barry,
Since the introduction of Jabiru’s proprietary carb needle in 2004 the carb functions to richen the mixture at full power (just like the conventional aircraft engines that operate at full rich for takeoff) resulting in lower EGT’s. When the throttle is reduced for cruise power the carb leans the mixture to a more economical fuel burn and not use a bit of extra fuel to help cool the engine (again – similar to the manual function in conventional aircraft engines where the pilot leans the mixture for a more economical cruise). Leaning as the throttle is reduced is a normal operation for the Bing carb with the Jabiru needle. Not so with the Bing std needle.
Pete
Pete Krotje
Jabiru USA Sport Aircraft, LLC
931-680-2800
www.usjabiru.com
Office Hours:
Mon - Thur 9:00am to noon and 1:00pm to 4:00 pm Central Time
Friday 9:00 am to 1:00pm Central Time
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of FLYaDIVE
Sent: Wednesday, April 29, 2015 4:17 PM
Subject: Re: Re: JabiruEngine-List Digest: 2 Msgs - 04/18/15
Rick,
Gas does not THIN... Gas vaporizes.
Barry
Rick Stockton
Europa N120EJ
Jabiru 3300
100%
On Sunday, April 19, 2015 12:21 AM, JabiruEngine-List Digest Server <[url=javascript:_e(%7B%7D,\'cvml\',\'jabiruengine-list(at)matronics.com\');]jabiruengine-list(at)matronics.com[/url]> wrote:
HTML Version:
Text Version:
1. 03:46 PM - Fuel Pressure ([url=javascript:_e(%7B%7D,\'cvml\',\'BobbyPaulk(at)comcast.net\');]BobbyPaulk(at)comcast.net[/url])
From: [url=javascript:_e(%7B%7D,\'cvml\',\'BobbyPaulk(at)comcast.net\');]BobbyPaulk(at)comcast.net[/url]
List
information ).
ignition coil.
Bobby ( age 76 )
Zodiac 601 XL "B"
From: Gary Aman <[url=javascript:_e(%7B%7D,\'cvml\',\'zeprep251(at)aol.com\');]zeprep251(at)aol.com[/url]>
ff.
On Apr 18, 2015, at 6:43 PM, [url=javascript:_e(%7B%7D,\'cvml\',\'BobbyPaulk(at)comcast.net\');]BobbyPaulk(at)comcast.net[/url] wrote:
List
Bobby ( age 76 )
Zodiac 601 XL "B"
ist" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-Listtp://forums.matronics.com_blank">http://www.matronics.com/contribution
BARRY CHECK 6
PostPosted: Wed Apr 29, 2015 3:47 pm    Post subject: JabiruEngine-List Digest: 2 Msgs - 04/18/15 Reply with quote
Rick,
Barry
Rick Stockton
Europa N120EJ
Jabiru 3300
100%
HTML Version:
Text Version:
List
information ).
ignition coil.
Bobby ( age 76 )
Zodiac 601 XL "B"
ff.
List
Bobby� ( age 76 )
Zodiac 601 XL "B"
