alternator
Goto page 1, 2  Next
BobbyPaulk(at)comcast.net
PostPosted: Fri Apr 24, 2015 12:05 pm    Post subject: alternator Reply with quote
List,
I have two flights of about 30 minutes each on my Jabiru 3300 after some repairs and a couple of modifications.
I changed the Alternator coils from 2 parallel circuits to 1 series circuit in accordance with Jabiru AVDALSR-087-1. It was working fine on the first flight and most of the second flight. Output was 14.6 volts while taxiing out. Halfway thru the second flight I turned on strobe lights to put a load on the alternator. I figure I was drawing no more than 11 amps. When I reduced power to enter downwind I smelled wires burning and noticed the battery voltage was down to 12.2. I turned off the strobes and landed.
On inspection I found every other coil ( 6 ) in the alternator burned black and the alternator no longer worked.
I am not going back with the original magnet / stator dynamo.
My question to the list is whether to go with the CAMit alternator or the Rotec. I am leaning toward the CAMit version since they are very familiar with the Jabiru / CAMit Engine.
Does anyone know if the belt on either one can be changed without removing the aluminum back plate?
Bobby
Zodiac 601 XL "B"
Jabiru 3300 S/N 1141
Sensenich 64" x 51" Prop
Bing Carb 260 Main & 290 Needle Jet
Status - Flying 236 hrs.
matronics(at)rtist.nl
PostPosted: Fri Apr 24, 2015 12:51 pm    Post subject: alternator Reply with quote
CAMit for sure. As you say, they know the engine very well (they built them for many years) and today sell new engines with just this alternator setup.
The aluminium spider needs to come off to change the belt, but that should be easy with the old alternator parts removed, and only a once-every-500-hours job.
Rob
On 4/24/2015 10:04 PM, BobbyPaulk(at)comcast.net (BobbyPaulk(at)comcast.net) wrote:
[quote] List,
Bobby
Zodiac 601 XL "B"
nuckollsr
PostPosted: Sat Apr 25, 2015 4:19 am    Post subject: alternator Reply with quote
alternator setup.
Rob
On 4/24/2015 10:04 PM, BobbyPaulk(at)comcast.net wrote:
List,
I was astounded to learn of what was touted to be
a 'Jabiru recommendation' to series up the windings
on the alternator for 'improved performance'.
This has the effect of DOUBLING the alternator's
AC output voltage . . . and yes, you'll see
improved bus voltage readings at low rpm.
To paraphrase the astute observation by one
of my favorite authors, "There ain't no such
thing as a free lunch."
Moving from parallel connection to series
connection doubles output voltage while
cutting current delivery capability by more
than 1/2. I.e. the POWER available from the
alternator is unchanged but delivered at
a higher voltage with lower current capability.
There ARE regulator designs which would exploit
virtually ALL the ENERGY available from the
alternator at ANY practical voltage.
In the legacy rectifier/regulator, current
flowing in alternator windings is a mirror
of that flowing out of the R/R. Rewiring the alternator
while retaining the legacy regulator is all
but guaranteed to produce the observed results.
Going from parallel to series COMBINED with an
upgrade of regulator technology would be a very good
thing to contemplate.
I'm having trouble believing that Jabiru
engineers made such a recommendation; I'll
bet it came from somebody down the distribution
chain. In any case, ill-conceived. Replacing
the alternator with a belt-driven, automotive
derivative is also a practical option.
Bob Nuckolls
AeroElectric Connection
P.O. Box 130
Medicine Lodge, KS 67104-0130
Mobile: 316-209-7528
Web: http://aeroelectric.com
PostPosted: Sat Apr 25, 2015 9:21 am    Post subject: alternator Reply with quote
Hello Bob,
As astounding as it sounds, this mod indeed comes from the Jabiru factory themselves. Run a search for AVDALSR87 on Google and you will find the PDF listed as the first hit, direct from the Jabiru site. There is a second version (AVDALSR87-2) with a bit more explanation around, but nowhere does either version mention the loss of current delivery capability. It just touts the ability to charge the battery at near-idle speeds. Several people asked Jabiru about it and they claimed no loss of power from this mod.
Considering the same current draw from the plane's electric system and the internal losses (= heat) in the alternator coil quadrupling at equal current draw with this mod (going from 1/2R to 2R), it is no surprise the coil will burn up.
The belt driven alternative has two positive effects. First, there's more electrical power available, also at low idle speed. Second, the belt drive dampens torque pulses which helps keep the flywheel bolts intact. Definitely te way to go.
Rob
> a 'Jabiru recommendation' to series up the windings on the alternator
> for 'improved performance'. This has the effect of DOUBLING the
> alternator's AC output voltage . . . and yes, you'll see improved bus
> To paraphrase the astute observation by one of my favorite authors,
> "There ain't no such thing as a free lunch."
> Moving from parallel connection to series connection doubles output
> voltage while cutting current delivery capability by more than 1/2.
> I.e. the POWER available from the alternator is unchanged but
> delivered at a higher voltage with lower current capability.
> There ARE regulator designs which would exploit virtually ALL the
> ENERGY available from the alternator at ANY practical voltage.
> In the legacy rectifier/regulator, current flowing in alternator
> windings is a mirror of that flowing out of the R/R. Rewiring the
> alternator while retaining the legacy regulator is all but guaranteed
> Going from parallel to series COMBINED with an upgrade of regulator
> technology would be a very good thing to contemplate.
> I'm having trouble believing that Jabiru engineers made such a
> recommendation; I'll bet it came from somebody down the distribution
> chain. In any case, ill-conceived. Replacing the alternator with a
> belt-driven, automotive derivative is also a practical option.
> Bob . . .
nuckollsr
PostPosted: Sat Apr 25, 2015 2:40 pm    Post subject: alternator Reply with quote
At 11:00 2015-04-25, you wrote:
Hello Bob,
That's sad . . . but I guess not a great surprise.
More and more companies have become so siloed and
victim to the 'let's farm that out' syndrome that
they loose command and control over critical aspects
of their products.
Agreed.
Yeah . . . but that PM alternator is so damned simple,
elegant and robust. With the right electronics, it COULD
be a significant ingredient in the recipe for success.
Rotax too . . .
I'm working on that . . .
Bob Nuckolls
P.O. Box 130
------------------------------ [quote][b]
nuckollsr
PostPosted: Sat Apr 25, 2015 2:42 pm    Post subject: alternator Reply with quote
Can anyone on the list give me a measurement of
AC volts developed by the stock, parallel wound
3300 PM alternator at idle speed. Need to know what
that speed is too . . .
Bob Nuckolls
P.O. Box 130
gilles.thesee(at)free.fr
PostPosted: Sun Apr 26, 2015 4:06 am    Post subject: alternator Reply with quote
Le 25/04/2015 18:00, Rob Turk a écrit :
Hello Bob,
Rob and all,
I'm afraid I could not find any of those documents through a Google
search, and the Jabiru official website doesn't seem to list them.
Would it be possible to obtain a direct link to those pdf's ?
Best regards,
Gilles
http://contrails.free.fr
PostPosted: Sun Apr 26, 2015 7:22 am    Post subject: alternator Reply with quote
Hi Bob,
I had the cowl off today so it was easy to measure. My engine runs 800rpm idle, which produces 7.2V AC. At 1000rpm I measured 9.0V AC. Please not that these were measured with a DVM and the alternator output is probably not a clean sine wave.
I didn't dare to leave the cockpit at higher rpm, but at 1400rpm my 'low charge' light goes out. Assuming linear beaviour that would be at 12.6V AC
Hope this helps,
Rob
On 4/26/2015 12:42 AM, Robert L Nuckolls III wrote:
> --> JabiruEngine-List message posted by: Robert L Nuckolls III
> <bob.nuckolls(at)aeroelectric.com> (bob.nuckolls(at)aeroelectric.com)
> Can anyone on the list give me a measurement of AC volts developed by
> the stock, parallel wound 3300 PM alternator at idle speed. Need to
> know what that speed is too . . .
> Bob . . .
europa471
PostPosted: Sun Apr 26, 2015 4:20 pm    Post subject: alternator Reply with quote
Gilles
Try this link:
http://jabiru.net.au/images/AVDALSR087-2_12_Pole_Alternator_Mod.pdf
If that doesn´t work, I´ll post the .PDF.
Lance
> Hello Bob,
Rob and all,
Best regards,
Gilles
nuckollsr
PostPosted: Sun Apr 26, 2015 7:21 pm    Post subject: alternator Reply with quote
At 19:19 2015-04-26, you wrote:
Sandford <lsandford(at)westnet.com.au>
Gilles
Try this link:
I was able to download using link above. I see
a citation for 12v (at) 900 rpm and elsewhere
a citation of 40V at 3000 rpm. These two
values are consistent with each other.
This says that the paralleled winding produces
about 20VAC at 3000 rpm . . . this was the
value I was looking for.
Thanks!
Bob Nuckolls
P.O. Box 130
PostPosted: Mon Apr 27, 2015 1:43 am    Post subject: alternator Reply with quote
Gilles
Try this link:
Lance and all,
Thank you for the link, and thank you for those who reponded privately.
It's great to get help so quickly.
Ironically, now Google works as expected and yields lots of responses^^!
Thanks again,
Best regards,
Gilles
PostPosted: Mon Apr 27, 2015 12:40 pm    Post subject: Alternator Reply with quote
List
I was getting 14.6 volts steady at 1200 and 1400 rpm while taxiing out. My amp meter hunts so I do not know what it was putting out ( Zero to 4 indicated ). After the first flight that had Icom radio, Dynon Efis, and the Ro-tec E mag I figured about five to seven amps with the radio not transmitting. The volt meter was still steady at 14.6.
One thing I did observe was when I put the battery tender on it it only took about 10 minutes or less for the green light to come on. It usually takes 25 to 30 minutes.
I believe the coils shorted out when I added load by turning on the strobes. After I removed the coils it looks like the varnish could have been rubbed off at the corner of the turn where the wires exit to the backside of the coils. I could not really tell since the wire was blackened and had no varnish left.
One circuit was burned black ( all 6 coils ) while the other circuit was in tact.
I knew it was a trade off by going to one series circuit in lieu of the 2 parallel but I was used to turning off the transponder on short final and the strobes after exiting the runway ( unless there was ground traffic).
Anyway I am afixin to order the CAMit 40 ~ 45 amp alternator and adapter kit. That ought to fix the problem unless I have another self induced uh-oh!
Thanks to all that responded ( no flames : )
bobby
nuckollsr
PostPosted: Mon Apr 27, 2015 2:23 pm    Post subject: Alternator Reply with quote
At 15:39 2015-04-27, you wrote:
List
was in tact.
self induced uh-oh!
bobby
Sadly, your observations on the series-connected
alternator 'experiment' were somewhat predictable.
Sorry you've had to suffer the indignities imposed
by the laws of physics.
The PM alternator has been poorly exploited for the
best it has to offer. PM alternators are simple, long
lived, robust and not terribly inefficient. Unfortunately,
the rectifier/regulator combinations have NOT evolved
with the best that power electronics has to offer.
We're doing the rudimentary proof of concept studies
for a PM alternator R/R that will offer greater
maximum output commensurate with the alternator's
real ability to convert mechanical motion into
electrical energy.
The belt driven alternator is a low-risk albeit
heavier and more expensive alternative. It may indeed
be the most practical solution depending on you
use your airplane.
But it's possible that a modern R/R configuration will
breath new life into the PM alternator concept with
increased performance and system reliability.
We shall see .. .
Bob Nuckolls
P.O. Box 130
BARRY CHECK 6
PostPosted: Tue Apr 28, 2015 7:38 am    Post subject: Alternator Reply with quote
Right you are Bob N.!
Things will NOT change until many more 'builders'...  Not Engineers, come to the realization that: You can't fool Mother Physics!  Physics is what it is and no matter how much hoping and praying you do, you CAN'T change it!
When this issue first came up years ago I posted something like:  You can't get blood from a stone and why not just install a small AUTOMOTIVE alternator with built in ACU!  All sorts of responses surfaced...  I don't want to loose the extra HP the alternator will require.  Too much weight.  What do I do with the built in unit...  DUH!  Remove it! The only acceptable response was: I don't have room to install it - No room under the cowl.  Now, here I have feeling for the poor builder.
Small alternators such as the MITSUBISHI are as small a large man's hand and put out 40 to 70 Amps.  Simple, easy to install, easy to diagnose, easy to regulate (built in), easy to replace if you breakdown at a remote airport...  Just SIMPLY EASY!  So, why kill yourself trying to get blood from a stone?  And I like Jabiru Engines...  I hate Rat-Tax (Rotex).
Barry
On Mon, Apr 27, 2015 at 6:21 PM, Robert L Nuckolls III <bob.nuckolls(at)aeroelectric.com (bob.nuckolls(at)aeroelectric.com)> wrote:
[quote]--> JabiruEngine-List message posted by: Robert L Nuckolls III <bob.nuckolls(at)aeroelectric.com (bob.nuckolls(at)aeroelectric.com)>
List
bobby
electrical energy.
use your airplane.
We shall see .. .
Bob Nuckolls
P.O. Box 130
Mobile: [url=tel:316-209-7528]316-209-7528[/url]
ne-List" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-List
">http://forums.matronics.com
le, List Admin.
nuckollsr
PostPosted: Tue Apr 28, 2015 8:24 am    Post subject: Alternator Reply with quote
To be sure, the universe runs on physics and
no matter what discipline one plies their
talents, it all comes down to properties of
materials and management of energy.
The evolution of the PM alternator has roots
on small bikes and RV's like snow-mobiles. They
often mounted a "lighting coil" on the crankcase
and spun a magnet close by to offer perhaps 20-30
watts of AC to light a headlamp.
The ghost of F. Kettering must have been smiling
down on the endeavor as individuals began to
ponder ways that the headlamp intensity could
be maintained over full range of engine rpm . . .
not limited to full bright at open throttle.
So the simple rectifier/regulator came along
with a crude voltage control profile that
prevented serious overcharging of the battery.
Keep in mind that ALL this was before rare
earth and SLVA technologies.
Yeah . . . it kinda worked okay. The regulators
were simple silicon controlled rectifiers that
were 'fired' as a dead short across the alternator
when the bus voltage got too high. Hence, the
alternator was fully loaded all the time. Furhter
it had to be inherently current limiting to keep
it from smoking when there were no system loads
and the battery was fully charged.
Then came rare earth magnets. About the same
time, SLVA batteries pushed their flooded
ancestors into a timely and well deserved
place in history. A new breed of R/R came along
which formed a bridge rectifier with SCR's in
two legs of the bridge for control by some
rudimentary electronics.
Again, not the best we knew how to do but
ADEQUATE to contemporary design goals. Examples
example of this now dated technology include
the successes logged by Rotax, B&C (The SD-8
was B&C's first product. I was a collaborator
on that development and helped them purchase
the sand-castings for Electro-Mech standby
generators for Bonanza's AND20000 pad
drive pad).
The improved alternators benefited from rare
earth, So while AVAILABLE AC power from
the alternator went up . . . DC power demands
on the airplanes being built went up too.
Sadly, the R/R did not evolve with the power
electronics side of the house.
There has never been anything inherently EVIL
or even grossly7 inept about the participants
in this saga. Each feature from alternator
to R/R, to battery, to evolution of the
all-electric OBAM aircraft was plotting along
with each technology driven by separate
marketing and business models most of which
hand nothing to do with the unique electrical
environment that was evolving on OBAM aircraft.
As a 45+ year observer and participant in art
and science of systems design and fabrication,
I can offer historical narrative above and
propose the next big step in the evolution
of the PM alternator as a practical, engine
driven power source.
The efficiency of the legacy triggered-bridge
rectifier is terrible. I judge that these
designs not only cripple the system's ability
to deliver at low rpm and may toss off 20
to 50% of total available energy as heat.
The next step borrows from the energy management
technologies ubiquitous in computers for decades.
In the mean time, I would be cautious about
bad-mouthing the PM alternator. Shortcomings
in performance had little to do with design
of the alternator and MUCH to do with design
of the R/R.
Did some development testing at B&C last week.
Will probably be back there again this week.
The ingredients that go into this recipe for
success have existed for decades . . . it's
a matter of picking the right combination . . .
for properties of materials and management of
energy.
Bob Nuckolls
P.O. Box 130
PostPosted: Tue Apr 28, 2015 8:55 am    Post subject: Alternator Reply with quote
You said it, Bob. Modern technology switching regulators allow for wide
input and constant output with high reliability, high efficiency and low
weight.
On a Jabiru, a switching regulator must be designed to work with ~5:1
input range (minimum 7 volt AC (at) 700rpm, maximum 35V(at)3300rpm.). The
original windings are designed to deliver 20A, so at cruise of 2700rpm
(~28V) it should deliver close to 500W of electrical power. If you'd use
an efficient switcher you can get ~85-90% available, which translates to
almost 30A(at)14.6V. Plenty for all but a flying Christmas tree. Oh, and a
switching regulator would make it possible to go to a 28V system as
well, saving weight on wiring.
Only concern I'd have with these is RF interference, these switchers
aren't particularly clean..
Rob
of the R/R.
energy.
Bob Nuckolls
P.O. Box 130
nuckollsr
PostPosted: Tue Apr 28, 2015 10:13 am    Post subject: Alternator Reply with quote
wide input and constant output with high reliability, high
efficiency and low weight.
~5:1 input range (minimum 7 volt AC (at) 700rpm, maximum 35V(at)3300rpm.
The 5:1 range target assumes that the alternator's
maximum rated ENERGY output is uniform over the
range of RPM . . . which it is not.
. The original windings are designed to deliver 20A, so at cruise of
2700rpm (~28V) it should deliver close to 500W of electrical power.
What gage wire is used to wind those stators?
If you'd use an efficient switcher you can get ~85-90% available,
which translates to almost 30A(at)14.6V. Plenty for all but a flying
Christmas tree. Oh, and a switching regulator would make it
possible to go to a 28V system as well, saving weight on wiring.
Based on the present state of development studies,
I would expect a pretty good boost at cruise RPM
perhaps as much as 50% over present capabilities.
I would also expect USEFUL output to MUCH lower
rpm levels than with the current technology. But
hundreds of watts at idle is not in the cards
without some re-design of the alternators. That
would be the next phase of system upgrades.
Switchmode regulators are widely used in a host
of RFI sensitive environments. There is NO design
that cannot be tailored to the most critical of
EMC environments.
I have desktop, consumer grade computer power supplies
sitting right next to amateur radio equipment capable
of sniffing microvolt level signals. I'm not suggesting
that there aren't occasional 'birdies' but I've yet
to be plagued by any of them. Got a nice HF transceiver
I'll be putting into service as soon as I can get a new
antenna up . . . I'll see if I need to modify those words.
In any case, there's a LOT of computers co-existing in
ham radio shacks . . . it can be done.
Bob Nuckolls
P.O. Box 130
PostPosted: Wed Apr 29, 2015 4:46 am    Post subject: Alternator Reply with quote
Guys
Sometimes I know the outcome before I start but I have been known to beat a dead horse.
Just ask my kids.
The engine was on a stand, the flywheel off, and the coil / stator was begging me to change it : )
bobby
nuckollsr
PostPosted: Wed Apr 29, 2015 6:22 am    Post subject: Alternator Reply with quote
At 07:45 2015-04-29, you wrote:
Guys
beat a dead horse.
Just ask my kids.
bobby
Do you have a 'carcass' stator I could have?
Bob Nuckolls
P.O. Box 130
PostPosted: Thu Apr 30, 2015 4:35 am    Post subject: Alternator Reply with quote
Bob,
You are welcome to the stator "carcass".
Send me an e-mail off list whether to send to the P.O. Box or a street address.
Hope you find something of interest.
Question: Has anyone installed the CAMit Alternator on a Jabiru 3300 mounted on a Zodiac 601.
I would like to verify it clears the upper left engine mount. I believe it does but would like to double check before ordering.
Bobby
Goto page 1, 2  Next
Page 1 of 2
