Posted: Sat Apr 25, 2015 6:54 am Post subject: Ideas on a "cost effective " ground power ? |
JeffS,
Have you tried a good old fashion battery charger (not a
maintainer). There are lots of chargers that are capable of putting
out 10-15 amps which should be plenty to keep the avionics & most
accessories running. (unless you have some need to run the
high-current loads for really long periods of time?)
I have an ancient Sears charger that can put out about 15 amps all
day long & I use it to float loads when I'm bench testing.
A quick goole search found this:
Be wary . . . not all 'battery chargers' are
the same. When crafting a source of ac mains
powered DC for ground ops, the power supply
needs to be reasonably well REGULATED and
noise levels no greater than an engine driven
alternator.
Years ago I sold a 25A, 13.8V regulated
power supply for this purpose. I think I sold
them for about $125. As I recall, we sold
about a dozen.
Years later, there are even more attractive
versions of this approach to ground-power.
Here is one such device.
http://tinyurl.com/k6gf8gt
These have a voltage adjust pot that will
probably allow you to turn the 15v output
down to 14v.
CAUTION: If you plan to have a battery on
line, then make sure the battery is fully
charged. These are power supplies, not battery
chargers. Alternatively, use the power supply
'barefoot' and leave the battery off line.
