OIL PRESSURE GAUGE FAULTY READING
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
Sharky
PostPosted: Wed Apr 29, 2015 9:10 pm    Post subject: OIL PRESSURE GAUGE FAULTY READING Reply with quote
On an AI-14RA engine, oil pressure gauge showing intermittent reading. Showing correct reading and then no reading at all. Now and then shows correct reading again or nothing.
Have connected another gauge to test and same problem, have tested wire connection between gauge and transmitter/sender unit, also good. Could plugs be faulty or sender unit.
What other test should I do.
Sounds to me like a bad connection but where?
Can you assist?
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
dsavarese0812(at)bellsout
PostPosted: Thu Apr 30, 2015 3:33 am    Post subject: OIL PRESSURE GAUGE FAULTY READING Reply with quote
I would suspect a faulty oil pressure sender.
Dennis
To: m14pengines-list(at)matronics.com
Sent: Thursday, April 30, 2015 12:10 AM
Subject: OIL PRESSURE GAUGE FAULTY READING
--> M14PEngines-List message posted by: "Sharky" <mavella(at)netactive.co.za (mavella(at)netactive.co.za)>
On an AI-14RA engine, oil pressure gauge showing intermittent reading. Showing correct and then no reading. Now and then shows correct reading again.
Have connected another gauge and same problem, have tested wire connection between gauge and transmitter/sender unit, also good. Could plugs be faulty or sender unit.
Can you assist?
http://forums.matronics.com/="http://www.matronics.com/Navigator?M14PEngines-List" target="_blank">orums.matronics.com/" target="_blank">http://forums.matronics.com
; -Matt Dralcontribution" target="_blank">http://www.matronics.com/contribution
Sharky
PostPosted: Fri May 01, 2015 12:08 am    Post subject: Re: OIL PRESSURE GAUGE FAULTY READING Reply with quote
Thanks Denis,
I was hoping to be something else, like the actual plugs but they look pretty solid to me.
Do you know where I can get a spare oil pressure sending unit?
PostPosted: Fri May 01, 2015 3:15 am    Post subject: OIL PRESSURE GAUGE FAULTY READING Reply with quote
Try Jill at M14P or Doug Sapp.
Dennis
Sent: Friday, May 1, 2015 3:08 AM
Subject: Re: OIL PRESSURE GAUGE FAULTY READING
Thanks Denis,
http://forums.matronics. href="http://www.matronics.com/Navigator?M14PEngines-List" target="_bl//forums.matronics.com/" target="_blank">http://forums.matronics.comh=
mark.bitterlich(at)navy.m
PostPosted: Fri May 01, 2015 12:16 pm    Post subject: OIL PRESSURE GAUGE FAULTY READING Reply with quote
Also George Coy. If he has them, his prices are very reasonable.
Sharky
PostPosted: Mon May 04, 2015 1:00 pm    Post subject: Re: OIL PRESSURE GAUGE FAULTY READING Reply with quote
Sorted. It was a faulty sender unit.
Thanks to all.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
