ELT Service Bulletin for ALL factory Produced SLSA LS1s
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List
dada4my2girls(at)gmail.co
PostPosted: Fri May 01, 2015 11:11 am    Post subject: ELT Service Bulletin for ALL factory Produced SLSA LS1s Reply with quote
Hello Nick,N326AL s/n 99
Has complied with the service bulletin AASB-1-5-2015
Joe Crosby
On Fri, May 1, 2015 at 12:41 PM, Nick Otterback <nick(at)flylightning.net (nick(at)flylightning.net)> wrote:
Recently a 406mhz ELT was inadvertently activated and left on by an owner. The last register owner of the Aircraft was Arion Aircraft LLC. The owner which activated it was the 2nd and not the original person to take delivery of the aircraft.
All 406 ELTs must be registered to the owner of the aircraft. Please read and follow the attached SB if you are an owner of a SLSA or ELSA LS1. Even if you have registered the 406 ELT is must be renewed on a periodic basis and yours may be expired. This is made clear during delivery of the aircraft and must be complied with.
This only applies to owners or operators of Factory Produced SLSA and ELSA aircraft. However if you are an owner of an kit built Lightning and a 406mhz ELT you may want to check it out.
Thank you and safe flying.
Nick Otterback
Arion Aircraft LLC
[url=tel:931-680-1781]931-680-1781[/url]
- The Matronics Lightning-List Email Forum -
http://www.matronics.com/Navigator?Lightning-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List All times are GMT - 8 Hours
You cannot download files in this forum
