fly4grins(at)gmail.com Guest
Posted: Tue May 26, 2015 6:20 am Post subject: Glide ratio, was Re: Best glide speed RV6A |
Hi Guys-
I took a look at the cited article and noticed a technical issue. Aside from some cross-border, or perhaps more likely cross-bureaucracy diction issues, the article implies that glide ratio varies with aircraft weight. As I'm sure most will recall, glide ratio is a function of form and speed. Changing the aircraft weight will result in a corresponding change in the speed at which best L/D occurs, but not the value of that ratio (not to any practical, or perhaps even measurable extent).
If interested, one can take a look at the Fed's Glider Handbook, Aerodynamics of Flight chapter, Glide Ratio section for a good refresher including a graphical explanation of the effect.
https://www.faa.gov/regulations_policies/handbooks_manuals/aircraft/glider_handbook/media/gfh_ch03.pdf
