		rvdave
				 Posted: Sat May 30, 2015 10:31 am    Post subject: NAV splitter |
				The quick build kit I have, the previous builder installed two Archer NAV antennae one in each wingtip   I'm assuming I can combine  these signals using a combiner or reverse splitter .  Will I be fighting a ghosting/corrupting signal using two signal sources?
  _________________ Dave Ford
Cadillac, MI |
		Bob Turner
				 Posted: Sat May 30, 2015 10:45 am    Post subject: Re: NAV splitter |
				This absolutely does not work.
 You will make a directional antenna which works very well in some directions and very poorly in others. Which direction depends on the exact lengths of the coax.
 One Archer works just fine, with some reduction in sensitivity when looking thru the airframe direction.
  _________________ Bob Turner
RV-10 QB |
				 Posted: Sat May 30, 2015 11:37 am    Post subject: NAV splitter |
				Nope - will not work.  The impedance match will be all wrong.
 Use one antenna for NAV, keep the other antenna as a backup comm - say for a handheld.  It would work a boat load better than the handheld's rubber ducky antenna.
 I made this antenna out of same scrap aluminum and small pieces of fiberglass.  I used an antenna tester to tune (most of these antennas are so far out that just slapping one in tends to produce disappointing results).  100nmi plus VOR range at altitude.
 Carl
  	  | Quote: | 	 		   On May 30, 2015, at 2:45 PM, Bob Turner <bobturner(at)alum.rpi.edu> wrote:
  Bob Turner
  RV-10 QB
  http://forums.matronics.com/viewtopic.php?p=442814#442814
 Dave Ford
 RV6 for sale
 RV10 building
 Cadillac, MI
				 Posted: Sat May 30, 2015 11:43 am    Post subject: NAV splitter |
				You can use one to Fe achieve Nav radio if you have two, but you don't want to try to combine them.
 Jesse Saint
 Saint Aviation, Inc.
 352-427-0285
 jesse(at)saintaviation.com
 Sent from my iPad
  	  | Quote: | 	 		   On May 30, 2015, at 1:31 PM, rvdave <rv610dave(at)gmail.com> wrote:
  Dave Ford
  RV6 for sale
  RV10 building
  Cadillac, MI
  http://forums.matronics.com/viewtopic.php?p=442813#442813
		rvdave
				 Posted: Sat May 30, 2015 11:53 am    Post subject: Re: NAV splitter |
				Exactly what I need to know, thanks.
Cadillac, MI |
		Kellym
				 Posted: Sat May 30, 2015 1:02 pm    Post subject: NAV splitter |
				I have installed two, because I have two nav/coms. If you only have one,
 perhaps with an ILS, you could use the second one for the GS. As others
 have said, you can't combine, and if you split for GS or second nav you
 lose about 50% of the signal strength.
KCHD |
		Bob Turner
				 Posted: Sat May 30, 2015 1:03 pm    Post subject: Re: NAV splitter |
				If your nav radio has separate inputs for vor and GS you can hook up one antenna to each and save tbe cost of a splitter.
 If you want to use it for a com radio you'll want to bend it up as much as possible, and trim about 10% of the length off the end. It won't be great but as Carl said it's better than the rubber duckie.
 For techies: the impedance match is fine, the issue is that depending on the direction of the signal, there will be phase mis-matches. When the phase difference is 180 degrees you'll get no signal.
RV-10 QB |
