RV-List Digest: 1 Msgs - 06/02/15
vincefrazier(at)gmail.com
PostPosted: Wed Jun 03, 2015 5:31 am    Post subject: RV-List Digest: 1 Msgs - 06/02/15 Reply with quote
Good common sense tip! Thanks Linn!
1. 02:37 PM - pouring from 'paint cans' (Linn Walters)
________________________________ Message 1 _____________________________________
Time: 02:37:57 PM PST US
Subject: pouring from 'paint cans'
I hope I'm not the only one that didn't know this trick .....
I bought a quart of 2-part hi-temp epoxy that came in small 'paint'
cans. I was trying to figure a way to pour the resin (3.3 to 1 by
weight mix) without having to clean out the 'groove' each time. What I
ended up with was two pieces of blue painters tape in the shape of a 'V'
that just covers the inner ring. I have to clean the inner ring before
each pour so the tape will stick to it. I pour the thick part (the 1)
first since it's more viscous than the other (3.3) and use a finger
(wear your rubber gloves!) to wipe the outside residue into the paper
cup on the scale. The resin on the underside of the tape will drain
back into the can, and you just have to remove and dispose of the tape.
Linn
