dlm34077
Posted: Wed Jun 03, 2015 10:07 am Post subject: throttle quadrant cable length |
A slightly longer length for all three cables is better than what is supplied.
I originally installed the standard cables on a standard IO-540 installation with the quadrant. I'm not sure there is a 'standard' quadrant installation but my quadrant seemed to end up where everyone elses has. It worked but at year 2 all three cables had frayed in spots and there was some melting of the plastic covering in spots on 1 or two.
Per advice gleaned from the boards, I replaced all three with custom cables from California Push-Pull. Same spec as Vans supplied except the plastic coating was higher temp I believe. The cables I ordered, installed and am flying with are 176-VTT-2-47, -51, and -72.
In retrospect, I wish I had gone with those in the original build.
On 6/3/2015 11:23 AM, David wrote:
The current CT Q-49.5 is 49.5 inches long. I seem to recall that another slightly longer length has been used on the IO540 installation on the quadrant 10s. Any comments?
David McNeill
N46007 900+
www.avast.com
Checked by AVG - www.avg.com
06/03/15 [b]
