kenryan
Joined: 28 Mar 2008 Posts: 1970 Location: Riley TWP Michigan
Posted: Thu Jun 04, 2015 8:45 am Post subject: Re: power supply for testing |
Read the Amazon user reviews. There is a high percentage of dissatisfied customers.
_________________ Joe Gores |
kenryan
Posted: Thu Jun 04, 2015 8:56 am Post subject: power supply for testing |
Thanks Joe. Any suggestions for an alternative?
On Thu, Jun 4, 2015 at 8:45 AM, user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
[quote]--> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)>
Joe Gores
http://forums.matronics.com/viewtopic.php?p=443008#443008
Electric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
Posted: Thu Jun 04, 2015 9:19 am Post subject: Re: power supply for testing |
Some builders just use an automotive battery along with a battery charger.
There is a used power supply on eBay, item number 360632236168 HP DL380 400W Power Supply HP. But it requires soldering. I am not necessarily recommending it, just saying that it is available.
Joe
ngeorge(at)continentalmot Guest
Posted: Thu Jun 04, 2015 9:22 am Post subject: power supply for testing |
Bulletproof:
http://www.hamradio.com/detail.cfm?pid=H0-004436
neal
Joe Gores
<![if !supportLineBreakNewLine]> <![endif]>
kenryan
Posted: Thu Jun 04, 2015 9:35 am Post subject: power supply for testing |
I am already set up with an auto battery plus charger (I use it to power a small ATV winch in my shop for lifting things) so it would be simple for me to go that route. Wasn't sure if that was safe power for expensive airplane stuff.
On Thu, Jun 4, 2015 at 9:19 AM, user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=443013#443013
jluckey(at)pacbell.net Guest
Posted: Thu Jun 04, 2015 9:44 am Post subject: power supply for testing |
See this thread from a couple of weeks ago:
Matronics Email Lists :: View topic - Ideas on a "cost effective " ground power ?
Matronics Email Lists :: View topic - Ideas on a "cost e...Matronics Email Lists BBS Forum Interface to the Matronics Email Lists Get Email Distribution Too! FAQ Search Memberlist Usergroups ...
View on forums.matronics.com
Preview by Yahoo
On Thursday, June 4, 2015 10:31 AM, Neal George <ngeorge(at)continentalmotors.aero> wrote:
Bulletproof:
neal
Joe Gores
[quote] [b]
Posted: Thu Jun 04, 2015 10:43 am Post subject: power supply for testing |
At 12:19 PM 6/4/2015, you wrote:
| Quote: | --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com>
There is a used power supply on eBay, item number 360632236168 HP DL380 400W Power Supply HP. But it requires soldering. I am not necessarily recommending it, just saying that it is available. |
See http://tinyurl.com/oyahfcf
Bob . . . [quote][b]
Posted: Thu Jun 04, 2015 10:45 am Post subject: power supply for testing |
At 10:09 AM 6/4/2015, you wrote:
Yes
argoldman(at)aol.com Guest
Posted: Sat Jun 06, 2015 2:58 am Post subject: power supply for testing |
What about a power supply from an old computer?
Rich
On Jun 4, 2015, at 1:41 PM, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote] At 10:09 AM 6/4/2015, you wrote:
Yes
Posted: Sat Jun 06, 2015 3:45 am Post subject: Re: power supply for testing |
| Quote: | What about a power supply from an old computer?
Rich |
A computer power supply could be used, but be careful with polarity. A computer power supply has both positive and negative outputs. The negative output has a much smaller output rating, so use the positive output. A computer power supply voltage is only 12 volts, whereas an aircraft usually operates between 13 and 14 volts. But that should not matter for most equipment.
Joe
ARGOLDMAN(at)aol.com Guest
Posted: Sat Jun 06, 2015 3:19 pm Post subject: power supply for testing |
Thanks Joe
Rich
In a message dated 6/6/2015 11:10:47 A.M. Central Daylight Time, fransew(at)gmail.com writes:
Rich
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=443127#443127===============================================
_-= = Use utilities Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ===================================================
Tundra10
Joined: 14 Jun 2010 Posts: 102 Location: Scarborough, Ontario
Posted: Sun Jun 07, 2015 8:39 am Post subject: power supply for testing |
I bought something like this. I don't remember which vendor.
This one has adjustable voltage. I bought one in this voltage range,
so that I could have 14.2V after dropping through a protection diode.
If the unit is not plugged in, but is "back fed" voltage from the
airplane battery, it will be damaged, so put an eBus diode in series,
then adjust the output voltage as desired.
http://tinyurl.com/lq7je4b
A computer power supply produces quite a lot of current at 5V, but not
so much as 12V. Some models require a load on the 5V output to
regulate properly.
Jeff Page
Dream Aircraft Tundra #10
| Quote: | Time: 03:58:56 AM PST US
Subject: Re: power supply for testing
Rich
>> Would this item be an acceptable choice for testing my electrical system?
Could it be used without any battery in the system? My avionics etc. are al
l Dynon.
>> http://www.amazon.com/Universal-Regulated-Switching-Computer-Project/dp/B
00D7CWSCG/ref=sr_1_5?ie=UTF8&qid=1433430384&sr=8-5&keywords=12+vol
t+DC+power+supply&pebp=1433430415435&perid=1MV8XVM71ACD3B1WWBYZ
>> Thanks,
>> Ken
dfritzj(at)yahoo.com Guest
Posted: Mon Jun 08, 2015 7:52 am Post subject: power supply for testing |
I just use a cheap 12v AGM battery for a UPS or alarm system. Works great, is safe, and I just charge it periodically. Dan
