Gascolator
ledson
PostPosted: Tue Jun 09, 2015 6:04 pm    Post subject: Gascolator Reply with quote
Does anyone know the size of the gascolator O ring on the Allegro 2000? Mine has started to leak.
Larry Edson
N4362C
ledson
PostPosted: Wed Jun 10, 2015 11:18 am    Post subject: Re: Gascolator Reply with quote
I spoke with Doug Hempstead at AllegroLSA. He is going to make me a
couple of the required O rings for the gascolator bowl.
Thanks Everyone.
Larry Edson
N4362C
jkgcpa(at)ix.netcom.com
PostPosted: Wed Jun 10, 2015 12:17 pm    Post subject: Gascolator Reply with quote
Doug at Allegro LSA has acquired new stocks of parts for the Allegro models.
You can contact him on the cc email or I think they joined the Allegro list.
He would know.
If you find out post it. Also how would you turn the gas off to change it
or the fuel filter.
Jerry
PostPosted: Wed Jun 10, 2015 12:22 pm    Post subject: Gascolator Reply with quote
Larry, did Doug give you any instructions on how to clean or change the fuel
filter?
Jerry
doug(at)allegrolsa.com
PostPosted: Wed Jun 10, 2015 1:07 pm    Post subject: Gascolator Reply with quote
Jerry,
To clean the fuel filter, simply remove from gascalator (I am sorry, but the
earlier Fantasy Air Allegro do NOT have a fuel shut off before the
gascolator, you must either drain fuel or put something under it to catch
the fuel, it will only be gravity fed and can be stopped by a small plug
{such as a small bolt}). Clean the filter with grease cutting soap and
water, blow out and let it dry completely, then re-install. We do carry
filters for the older Allegro if needed.
Doug
Douglas Hempstead
LSA America, Inc.
231 US Hwy 158 East
Littleton, NC 27850
252-586-1200 - office
252-586-1203 - fax
www.allegrolsa.com
ledson
PostPosted: Wed Jun 10, 2015 3:07 pm    Post subject: Re: Gascolator Reply with quote
Thanks Everyone.
Larry Edson
N4362C
