battery on the firewall
dlm34077
PostPosted: Tue Jun 16, 2015 8:14 am    Post subject: battery on the firewall Reply with quote
Any battery in the engine compartment needs insulation. There is an aluminum/foam material to line the sides/bottom of your battery box. Temps under the cowl get mighty warm after shutdown; if practical oil door should remain open to vent some of the heat.
www.avast.com [quote][b]
