How do you climb
AirEupora
PostPosted: Sat Jun 13, 2015 6:12 am    Post subject: How do you climb Reply with quote
For first time I climbed up to 85k. I set the throttle full for five minutes then I backed off. I was at 3000. I continued the climb, but had to increase the power to full to make it to 85k.
What method do you use the climb to altitude?
Rick Stockton
Europa XS N120EJ
JABIRU 3300L
jerryvmd
PostPosted: Sat Jun 13, 2015 7:26 am    Post subject: How do you climb Reply with quote
I fly a Zodiac601 with 3300 and 400hours. I use full throttle during
climb to which ever altitude but monitor CHT's. If a hot day and CHT's
start to reach 330-340 then I level off and let temps return to normal
than start the climb again. I CHT's stay in normal range it shouldn't
matter how you climb.
Rick Stockton
Europa XS N120EJ
JABIRU 3300L
