Fuel in Vent Lines
Guy Buchanan
PostPosted: Wed Jun 17, 2015 12:59 pm    Post subject: Fuel in Vent Lines Reply with quote
Thanks for all the help on the last set of questions. I'm moving along
nicely. One more, though. I'm getting a little fuel coming out the vent
lines, and my idle seems to wander between 1800 and 2200, mostly towards
2200. I seem to remember a problem with "weak / bad" float needles in
the past and wonder if my engine might be of that vintage. (Purchased
new 2011.) Are there different "strength" float needles for 912's? I
haven't sync'd the carbs yet, but don't think things are running
exceptionally rough. (At least not by 582 standards!) I'll do so this
week but are the carb floats that sensitive to vibration?
Guy Buchanan
Ramona, CA
Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded
Now a glider pilot, too.
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
lcfitt3(at)gmail.com
PostPosted: Wed Jun 17, 2015 5:24 pm    Post subject: Fuel in Vent Lines Reply with quote
Larry,
Thanks again for the reminder and sorry I needed it. Attached is the
picture. And you are correct, the hole is drilled right through the weld
bead. Typically, I will dill a 1/8" hole as a pilot hole then go up to the
3/16.
Lowell
Sent: Wednesday, June 17, 2015 1:58 PM
To: "Kitfox list" <kitfox-list(at)matronics.com>
Subject: Fuel in Vent Lines
2200. I seem to remember a problem with "weak / bad" float needles in the
past and wonder if my engine might be of that vintage. (Purchased new
2011.) Are there different "strength" float needles for 912's? I haven't
sync'd the carbs yet, but don't think things are running exceptionally
rough. (At least not by 582 standards!) I'll do so this week but are the
Guy Buchanan
Ramona, CA
