Gordon Anderson
Posted: Tue Jul 07, 2015 2:01 pm Post subject: A-920 throttle / mixture cable |
Does anyone have experience using the Aircraft Spruce teflon lined A-920 cables with CableSafe2 or similar fittings at each end (quadrant installation) instead of the Van's or ACS A-1550 throttle cable?
I am struggling with alignment issues using the Vans cable bracket and wonder if this arrangement might give just a little more flexibility to avoid the cable hitting the bottom of the sump. I have already "adjusted" the bracket to give as much clearance as possible, but especially on the mixture side the misalignment is more than the 8° the push-pull cable normally allows.
Gordon Anderson
Switzerland
flying-nut(at)cfl.rr.com Guest
Posted: Tue Jul 07, 2015 2:43 pm Post subject: A-920 throttle / mixture cable |
I too struggled with the engine cables. I didn't route the cables
through the Adel clamps on the sub-panel. Gained a little 'slack' by
going straight to the Heyco bushings.
Linn
On 7/7/2015 5:58 PM, Gordon Anderson wrote:
Gordon Anderson
Switzerland
Checked by AVG - www.avg.com
