jgamtmann2(at)gmail.com Guest
Posted: Fri Jul 17, 2015 3:27 pm Post subject: Voltage reducer |
This is not aircraft related (but I do have an RV6) but is electronic related. Many years ago I converted an old Porsche 356 from 6V to 12V. There were no 12V windshield wiper motors available so I had to use the original 6V wiper motor which drew about 5-10A. Speed was controlled with a rheostat, but adding another dropping resistor generated heat and made the speed control ineffective. Someone assembled a transistor circuit for me that dropped the 12V supply to a constant 6V (independent of current draw) and everything worked well. I am now restoring this car and this device became lost. Does anyone of you electronic experts (maybe Bob N) know of a circuit I can build or purchase a device that will give me the constant 6V at 5 or 10A?
Jurgen Amtmann
Joined: 28 Mar 2008 Posts: 1961 Location: Riley TWP Michigan
Posted: Sat Jul 18, 2015 10:21 am Post subject: Voltage reducer |
At 09:57 PM 7/17/2015, you wrote:
I've used several similar products and they seemed to
be of good value. You will want to limit the 'travel'
on the control potentiometer such that output never
exceeds 7v on a 14v system. The stock controller will
allow output all the way up to what ever the bus
voltage is.
You can do this with a mechanical stop on a pointer
knob . . . or perhaps add a resistor in series with
the potentiometer body such that full travel on
the pot represents only 1/2 of the original electrical
travel.
Bob . . . [quote][b]
