overheating
turbot
PostPosted: Mon Aug 10, 2015 8:53 pm    Post subject: overheating Reply with quote
Got a model 2 KF with 582 that's getting to warm 180-200 under load.
Did a bunch of reading & came up with this plan.
On next trip to airport am going to try the following in stages;
- check coolant mix
- drop rad 1" to get into more airflow, & fill 1" space with foam to seal gap ( have standard ( I think ) 4"ish high rad under cabin )
- check for a thermostat & check its temp setting
- pull rad & check for scale buildup
May try a laser thermometer on head to check the temp gauge also.
Anyone been through this & want to add anything.
Guy Buchanan
PostPosted: Mon Aug 10, 2015 10:36 pm    Post subject: overheating Reply with quote
That's what I did and it worked for everything but the hottest (110F) days.
Guy Buchanan
Ramona, CA
Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. flying again.
Now a glider pilot, too.
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
