Roll trim
gregsmi
PostPosted: Tue Aug 18, 2015 7:47 am    Post subject: Roll trim Reply with quote
We have a Pulsar owner wanting to install roll trim. Does anyone have a picture he could go by?
Thanks for all the suggestions on the radio noise. I have gone through most of the ground wires with no improvement. Yesterday, I disconnected the capacitor that is connected to the voltage regulator, it tested good, reinstalled it and no more static. Now I am chasing a breakup in transmission. It occurs about every 5 seconds, like something switches off and on. It cannot be seen in the power to the panel so I am thinking about going back to the voltage regulator. Experimental is definitely a teaching experience in so many different occupations.
Having fun in Kansas,
Greg
w7ikt(at)fly-web.us
PostPosted: Tue Aug 18, 2015 10:21 am    Post subject: Roll trim Reply with quote
What brand/type of radio.  Google the problem - could be a known problem with the radio.  Inspect and tighten the ground and power lead to the radio and antenna coax.
Get a field strength meter.  Little box with antenna and see if the signal changes when you transmit.  You could also try a aviation hand-held.  A VHF swr/power meter will also tell a story.  This sounds like a good opportunity to get some test equipment for your ham shack.  While you are at it get a frequency counter too. Smile
Greg
God Bless,
Bob (W7IKT) & Carol (N5CBQ) Heiser
Shaving the way to Conquer Kid's Cancer
bernard.wilder2(at)gmail.
PostPosted: Tue Aug 18, 2015 2:34 pm    Post subject: Roll trim Reply with quote
Try a different capacitor.
Bernie Wilder
On Tue, Aug 18, 2015 at 2:21 PM, Bob Heiser <w7ikt(at)fly-web.us (w7ikt(at)fly-web.us)> wrote:
[quote] What brand/type of radio.  Google the problem - could be a known problem with the radio.  Inspect and tighten the ground and power lead to the radio and antenna coax.
Greg
God Bless,
arget="_blank">http://www.matronics.com/Navigator?Pulsar-List
tp://forums.matronics.com
