Antenna Question
ogdenk
PostPosted: Wed Aug 19, 2015 6:30 am    Post subject: Antenna Question Reply with quote
I'm finishing up my RV-10 wings and would like to have (most) everything done before I move on. I am contemplating wingtip VOR antenna(s) and wonder if these can also be used for glideslope? I expect most navigation will be from gps but I would like to have an operating VOR as well.
Thanks for any thoughts/comments.
Kent
ARGOLDMAN(at)aol.com
PostPosted: Wed Aug 19, 2015 6:33 am    Post subject: Antenna Question Reply with quote
The GS antenna is smaller than the VOR antenna so you can physically do it, however you can just use the VOR antenna with a splitter made for the purpose. You get a little loss, but I think it is trivial.
Rich
In a message dated 8/19/2015 9:30:56 A.M. Central Daylight Time, ogdenk(at)upstate.edu writes:
Kent
List href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
rnewman(at)tcwtech.com
PostPosted: Wed Aug 19, 2015 6:53 am    Post subject: Antenna Question Reply with quote
Yes. A vor / glide slope splitter works. I have that exact setup in my rv-10.
Bob Newman.
On Aug 19, 2015, at 10:29 AM, Kent Ogden <ogdenk(at)upstate.edu (ogdenk(at)upstate.edu)> wrote:
[quote] I'm finishing up my RV-10 wings and would like to have (most) everything done before I move on. I am contemplating wingtip VOR antenna(s) and wonder if these can also be used for glideslope? I expect most navigation will be from gps but I would like to have an operating VOR as well.
Kent
Kellym
PostPosted: Wed Aug 19, 2015 8:04 am    Post subject: Antenna Question Reply with quote
Depending on the navcom you have, some have internal splitters and just
need VOR antenna connection
in my rv-10.
Bob Newman.
> Kent
--> http://www.matronics.com/Navigator?AeroElectric-List
<3D%22http://www.matronics.com/contribution%22>
Kelly McMullen
KCHD
peter(at)sportingaero.com
PostPosted: Wed Aug 19, 2015 9:07 am    Post subject: Antenna Question Reply with quote
Yep, the SL-30 in my RV-6 works very well for localiser and glideslope
from a wing tip antenna with a single feed.
Peter
On 19/08/2015 17:02, Kelly McMullen wrote:
<kellym(at)aviating.com>
just need VOR antenna connection
> in my rv-10.
> Bob Newman.
>> Kent
> <3D%22http://www.matronics.com/contribution%22> *
