jgamtmann2(at)gmail.com Guest
Posted: Fri Aug 21, 2015 8:17 am Post subject: Master disconnect |
On the subject of "Master Disconnect" or Master Switch: If a manual switch is desired, Waytechwire has a selection of disconnect switches rated at hundreds of Amps. used in commercial vehicles. I use one in my Airstream to disconnect the battery in case of emergency (battery is mounted between tow vehicle and trailer and heavy wiring in trailer). I had considered mounting a manual switch in the RV6, next to the battery with a shaft extension to the dash. Simple, reliable etc. Jurgen Amtmann
http://www.waytekwire.com/item/44080/Heavy-Duty-Battery-Master/
