Cleveland static port.
flysrv10(at)gmail.com
PostPosted: Thu Sep 03, 2015 2:35 pm    Post subject: Cleveland static port. Reply with quote
Hi,
Anyone using Cleveland's static ports? Is accurate? If so, how did you determine that it is accurate?
Thanks.
Do not archive.
Rob Kermanj
Sent from my iPad
Tim Olson
PostPosted: Thu Sep 03, 2015 2:51 pm    Post subject: Cleveland static port. Reply with quote
I have the rounded Cleveland ports. They are pretty accurate. I think
mine read about 2kts low
in cruise. The other ones I had were off by 8kts. You have to fly the
3 or 4-way GPS
course to determine if they're accurate and know the OAT and everything.
Kevin Horton has a good spreadsheet on that. Here are some links. The
3rd link is
the spreadsheet.
http://www.kilohotel.com/rv8/
http://www.vansairforce.com/community/showthread.php?p=1009217
http://www.kilohotel.com/rv8/rvlinks/GPS_PEC.XLS
On 9/3/2015 5:31 PM, Rob Kermanj wrote:
Hi,
Thanks.
Do not archive.
Rob Kermanj
Sent from my iPad
carl.froehlich(at)verizon
PostPosted: Thu Sep 03, 2015 3:51 pm    Post subject: Cleveland static port. Reply with quote
I had the old Cleveland ports on the RV-8A - the version that was flush with
the outside skin. Like Tim they were well off in airspeed. I ended up
fixing the problem by drilling a 1/16" hole in the center of a 3/16" round
head rivet, cutting the head off and then using epoxy to glue the head on
the Cleveland static port. This provided enough height to solve the
problem.
On the RV-10 I just used a couple of 3/16" rivets for the static port
(AN470AD6-14 from Van's). I drilled a small hole all the way through the
rivet (get a handful of rivet as it is not easy to keep the hole centered
the whole way through the rivet). The drilled rivets are mounted through
3/16" holes in the fuselage in the standard spots with a touch of pro-seal
(or epoxy of your choice). On the inside of the fuselage skin is a 1"
diameter 1/8" thick piece of aluminum (with the same 3/16" hole in the
center) that is pro-sealed over the rivet shank and to the inside of the
fuselage skin. This provides a rigid mount for the rivet and attached
tubing. A 1/4" nylon tube slides over the rivet shank, with more pro-seal,
to make the connection.
The static ports proved to be very accurate.
Carl
PostPosted: Thu Sep 03, 2015 6:20 pm    Post subject: Cleveland static port. Reply with quote
Thanks guys for the answers.
I have the Van's method with the rivet head as the static port. At altitude, if I open the vents, the plane loses a few feet of altitude. My pitot/static connections are tight and I can only attribute the issue to a leak right at the rivet head. The RTV method of attaching the tubing to the rivet might be the case. It looks visually good but I don't dare tug on the connection.
Cleveland's port might be the fix.
Do not archive.
Rob Kermanj
Sent from my iPad
[quote] On Sep 3, 2015, at 6:48 PM, Carl Froehlich <carl.froehlich(at)verizon.net> wrote:
problem.
Carl
PostPosted: Thu Sep 03, 2015 6:22 pm    Post subject: Cleveland static port. Reply with quote
Thank for the links Tim. Might have to this route.
Rob Kermanj
Sent from my iPad
On Sep 3, 2015, at 5:48 PM, Tim Olson <Tim(at)MyRV10.com> wrote:
I have the rounded Cleveland ports. They are pretty accurate. I think mine read about 2kts low
in cruise. The other ones I had were off by 8kts. You have to fly the 3 or 4-way GPS
Kevin Horton has a good spreadsheet on that. Here are some links. The 3rd link is
the spreadsheet.
> Hi,
> Thanks.
> Do not archive.
> Rob Kermanj
> Sent from my iPad
glastar(at)gmx.net
PostPosted: Thu Sep 03, 2015 9:48 pm    Post subject: Cleveland static port. Reply with quote
................. and know the OAT and everything.
very nice information Tim, on that item, where did you put your OAT to
get accurate readings?
Cheers Werner
Tim Olson
PostPosted: Fri Sep 04, 2015 3:42 am    Post subject: Cleveland static port. Reply with quote
It's out under the wing, next to one of the inspection panels, far enough to be out of the prop wash. In the shade too.
> I have the rounded Cleveland ports. They are pretty accurate. ................. and know the OAT and everything.
very nice information Tim, on that item, where did you put your OAT to get accurate readings?
Cheers Werner
whodja
PostPosted: Fri Sep 04, 2015 4:00 am    Post subject: Re: Cleveland static port. Reply with quote
I spoke with SteinAir this week about the new heated AOA and in discussion I learned that when installing a static port it cannot be flush or you will get false readings. The port must be proud even if a fraction.
Tal Holloway
RV-10 Empennage comp
QB wings and fuselage
glastar(at)gmx.net
PostPosted: Fri Sep 04, 2015 5:35 am    Post subject: Cleveland static port. Reply with quote
Thanks Tim!
> Cheers Werner
PostPosted: Sat Sep 05, 2015 11:40 am    Post subject: Cleveland static port. Reply with quote
Thanks Tal. Makes sense some Cleveland revised their design to make it project beyond the skin.
Do not archive.
Tal Holloway
http://forums.matronics.com/viewtopic.php?p=446784#446784
