jim(at)gunn.org.uk Guest
Posted: Sun Sep 06, 2015 5:32 am Post subject: Europa XS Tri Gear Kit with Rotax 912S and Airmaster AP322 |
Unable to fly due to loss of medical I have a part complete Europa XS Tri Gear Kit with factory completed tail plane, fin, ailerons and trim tabs. Full factory firewall forward kit including Europa supplied Rotax 912S in the manufacturers box and vacuum system, Airmaster AP322 Constant speed propeller and controller, included is the factory steel box section build trolley. Most of the work is still to be done, wings are not closed, cockpit module is not in. Mod 73 has not been completed, The resin has all expired. The kit is located in Norfolk, UK. I can assist with UK delivery if required and if it’s sold for a sensible amount.
Also included is:-
Fuel Contents system
Mod 56 Speed Kit
Mod 61 Stall Warner
Mod 62 Replacement of tail plane torque tube drive pins.
Mod 63 Instrument panel fascia’s
Mod 65 Finger Brakes
Mod 69 Wing Tie down
Mod 71 Tri Gear - nose gear bungee replacement by springs
Mod 72 Undercarriage mounting frame strengthening
Rotax Flydat plus analogue engine gauges
K&N Air Filter and Fluid
Manifold Pressure Gauge
Air Speed Indicator, Falcon Altimeter, Falcon VSI, Ray Allen Artificial Horizon, Ray Allen Directional Gyro, Turn coordinator, Davtron M800 chronometer
Resin Metering pump
Various wire and circuit breakers
No sensible offer refused.
Jim Gunn
jim (at) gunn.org.uk
