danny shepherd
Joined: 27 Jan 2006 Posts: 117 Location: north Wales, United Kingdom
Posted: Tue Sep 15, 2015 5:09 am Post subject: radio interferance |
Hi All,
Are there any avionics expert who might be able to help ?
I have a Funkwerk ATR833 which has worked ( bar having a new face fitted
) extremely well over the last six years. but now works fine until I
start the engine, then a lot of interference, virtually unreadable both
transmitting and receivering. I did have the panel off to remove the
hard wiring for a gps which I dont need anymore. Sounds like a grounding
problem to me.
I would appreciate any advise.
Regard. Danny. G-c.e.r.i TRI XS
rampil
Posted: Tue Sep 15, 2015 9:47 am Post subject: Re: radio interferance |
It is nearly impossible to remotely diagnose this problem without wiring diagrams, photos of the install, etc. Generically, grounding is a possibility.
So, did you check all the resistance values of ground pins on the radio
and the case all the way back to the engine block or negative battery
terminal with a quality ohm meter? All should certainly be less than 0.5
ohms. Generically, there should be no ground loops, all grounds go to
a single point in the panel, then to the other side of the firewall.
Good luck!
danny shepherd
Posted: Thu Sep 17, 2015 1:39 am Post subject: radio interferance |
Hi Ira,
Thanks for your input. I trailed RI back home from the
airfield so I can work on her in comfort . hopefully I will be able
to sort the problem.
Cheers Danny. G- c.e.r.i.
On 15/09/2015 18:47, rampil wrote:
Good luck!
Ira N224XS
http://forums.matronics.com/viewtopic.php?p=447092#447092
Checked by AVG - www.avg.com
