Rich Langer
Posted: Mon Oct 19, 2015 5:12 am Post subject: Wing Walk |
I had some sort of rubber material on my wing walk which is coming off. I stripped it off and now I need to put some kind material on it and make it non-skid. I am thinking of having it sprayed with pickup bed lining material. Has anyone done this ? What other options are there? Thanks in advance.
Rich
clouddog22(at)gmail.com Guest
Posted: Mon Oct 19, 2015 5:56 am Post subject: Wing Walk |
Rich, I did the exact same thing. I used Line-X!! My local guys did a great job. It looks great, is durable and works! On Oct 19, 2015 8:39 AM, "Rich Langer" <rlanger2(at)comcast.net (rlanger2(at)comcast.net)> wrote:[quote]--> Yak-List message posted by: "Rich Langer" <rlanger2(at)comcast.net (rlanger2(at)comcast.net)>
Rich
http://forums.matronics.com/viewtopic.php?p=448079#448079
Posted: Mon Oct 19, 2015 6:21 am Post subject: Wing Walk |
There is a brush on wing walk compound available from Spruce, in
quarts. Easy to brush on and touch up when necessary.
http://www.aircraftspruce.com/catalog/cspages/randolphwingwalk.php?clickkey=21351
A. Dennis Savarese
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
On 10/19/2015 9:12 AM, Rich Langer wrote:
Rich
Ernie
Posted: Mon Oct 19, 2015 6:32 am Post subject: Wing Walk |
I considered using pavers from Home Depot. Comes in all different colors
On Mon, Oct 19, 2015 at 10:18 AM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
[quote]--> Yak-List message posted by: "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>
There is a brush on wing walk compound available from Spruce, in quarts. Easy to brush on and touch up when necessary.
A. Dennis Savarese
[url=tel:334-546-8182]334-546-8182[/url] (mobile)
www.yak-52.com
Skype - Yakguy1
| Quote: | --> Yak-List message posted by: "Rich Langer" <rlanger2(at)comcast.net (rlanger2(at)comcast.net)>
Rich
pfstelwagon(at)earthlink. Guest
Posted: Mon Oct 19, 2015 8:26 am Post subject: Wing Walk |
I had my wing walk sprayed with Bed Liner material, looks great but beware . When you wash the plane the wing walk will be slick.
Frank
Posted: Mon Oct 19, 2015 8:37 am Post subject: Wing Walk |
Guys,The reinforcement directly underneath the wing walk area is greatly lacking and many aircraft wing walks are "spongy" and in need of help especially up towards the leading edge. Rather you use the stock tread, bed liner, or whatever you should first overlay the area with a piece of .050 7075-T6. You might be wise to apply your non skid to this reinforcement, then attach the reinforcement to the aircraft. This will make future "re-coating" easier and you won't have to worry about messing up your paint job or worrying about the coating sticking to the oil soaked rivet heads and skin laps.
The stock wing walk "tread" is available and in stock.
Best from Omak,
Doug
On Mon, Oct 19, 2015 at 6:12 AM, Rich Langer <rlanger2(at)comcast.net (rlanger2(at)comcast.net)> wrote:
Rich
wlannon(at)shaw.ca Guest
Posted: Mon Oct 19, 2015 9:44 am Post subject: Wing Walk |
The original wing walk (CJ6/6A) is made from dead soft aluminum (likely 1100 series). Junk it and follow Doug’s advice. Doug’s choice of material is quite interesting since the 7000 series alloys are the strongest aerospace al. alloys available. That’s great but as a result they are also very susceptible to corrosion and require proper preparation and of course are by far the most expensive. 2024 T3 would also be a great choice but not cheap.
6061 T6 is quite adequate strengthwise (and corrosion resistance is better), in either .050” or .063”. With the thinner one I recommend retaining the 1 mm doubler under the leading edge of the original wing walk.
Regardless of the material choice it really is necessary to roll the leading edge to conform to the wing curvature.
The Randolph wing walk compound is excellent and is the only one I use for this purpose. Preparation is exactly the same as painting the aircraft no matter what you use if you expect it to stay on. Clean, etch, conversion coat and high quality primer.
Walt
Sent: Monday, October 19, 2015 9:34 AM
Subject: Re: Wing Walk
Guys, The reinforcement directly underneath the wing walk area is greatly lacking and many aircraft wing walks are "spongy" and in need of help especially up towards the leading edge. Rather you use the stock tread, bed liner, or whatever you should first overlay the area with a piece of .050 7075-T6. You might be wise to apply your non skid to this reinforcement, then attach the reinforcement to the aircraft. This will make future "re-coating" easier and you won't have to worry about messing up your paint job or worrying about the coating sticking to the oil soaked rivet heads and skin laps.
Best from Omak,
Doug
Rich
href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List
Posted: Mon Oct 19, 2015 10:08 am Post subject: Wing Walk |
Forgot to mention: Use a new soft roller to apply the wingwalk, not a brush.
Walt
Sent: Monday, October 19, 2015 10:40 AM
Walt
Best from Omak,
Doug
Rich
href="http://www.matronics.com/Navigator?Yak-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
Viperdoc
Posted: Mon Oct 19, 2015 6:25 pm Post subject: Wing Walk |
Buy the clear film from Aircraft Spruce. It is not slick when wet.
Doc
On Oct 19, 2015, at 11:22 AM, Frank Stelwagon <pfstelwagon(at)earthlink.net (pfstelwagon(at)earthlink.net)> wrote:
[quote] I had my wing walk sprayed with Bed Liner material, looks great but beware . When you wash the plane the wing walk will be slick.
Frank
_________________ Viperdoc |
Viperdoc
Posted: Mon Oct 19, 2015 6:30 pm Post subject: Wing Walk |
How did that work out in the roll?
Doc
On Oct 19, 2015, at 9:28 AM, Ernest Martinez <erniel29(at)gmail.com (erniel29(at)gmail.com)> wrote:
[quote]I considered using pavers from Home Depot. Comes in all different colors
JL2A
Posted: Thu Oct 22, 2015 5:22 pm Post subject: Re: Wing Walk |
anyone tried replacing wing walk with a sheet of composite material, carbon or glass fibre..?
