		amekler
				 Posted: Sat Oct 10, 2015 7:28 am    Post subject: where is static port located? |
				my pitot static transponder check is due and my avionics guy wants to know where my static port is located. i 've looked but can't seem to find it
 Alan
  N668G
		john(at)trollingers.com Guest
				 Posted: Sat Oct 10, 2015 8:31 am    Post subject: where is static port located? |
				you should have one on the left and right side of the plane in the tail cone.
 On Sat, Oct 10, 2015 at 11:28 AM, amekler <amekler(at)metrocast.net (amekler(at)metrocast.net)> wrote:
 [quote]--> RV10-List message posted by: "amekler" <amekler(at)metrocast.net (amekler(at)metrocast.net)>
  Alan
   N668G
  http://forums.matronics.com/viewtopic.php?p=447797#447797
   FORUMS -
  b Site -
            -Matt Dralle, List Admin.
		bdgillespie215(at)gmail.c Guest
				 Posted: Sat Oct 10, 2015 8:35 am    Post subject: where is static port located? |
				There should be two. Both on the tail cone just forward of the horizontal stabilizer. Ref section 10-25 in plans.
 Byron
  	  | Quote: | 	 		   On Oct 10, 2015, at 11:28 AM, amekler <amekler(at)metrocast.net> wrote:
  Alan
  N668G
		rnewman(at)tcwtech.com Guest
				 Posted: Sat Oct 10, 2015 8:56 am    Post subject: where is static port located? |
				Empennage,  about 1 ft in front of horizontal stabilizer.
 Bob Newman
 TCW Technologies, LLC
 610-928-3420
  Alan
  N668G
		Albert Gardner
				 Posted: Sat Oct 10, 2015 8:57 am    Post subject: where is static port located? |
				I take it that you are not the builder. Most static ports are  on each side
 of the tail cone near the longeron. They are ofter the round head of a pull
 rivet but some have installed commerical static ports that might be larger.
 If they are completely flush they  don't seem to work as will and have
 errors. If you have angle-of-attack the AOA port is on the bottom of the
 pitot tube.
 Albert Gardner
 N991RV
 Yuma, AZ
  _________________ RV-9A N872RV
RV-10 N991RV |
		cooprv7(at)yahoo.com Guest
				 Posted: Sat Oct 10, 2015 9:07 am    Post subject: where is static port located? |
				Alan,
    Typically it is on both sides of the fuselage aft of the luggage door by a couple of feet about midway up the side.  Should be a small silver disk or large pop rivet.
 Marcus
  Alan
  N668G
