jmjones2000(at)mindspring Guest
Posted: Thu Nov 12, 2015 4:57 pm Post subject: Stratux Build |
For those of you looking for an inexpensive solution for an ADS-B in (with AHRS if desired), this appears to be a relatively easy project. I am going to tackle it early next month.
The website has step-by-step instructions and a list of exact parts to purchase.
https://github.com/ssokol/stratux/wiki/Stratux-Beginner's-Guide
markdonahue
Joined: 16 Dec 2012 Posts: 16 Location: bainbridge island washington
Posted: Thu Nov 12, 2015 5:15 pm Post subject: Stratux Build |
Would love to hear how your project works out and how difficult it is (was)
to get it put together an place in service.
Mark Donahue
_________________ Mark Donahue |
deej(at)deej.net Guest
Posted: Thu Nov 12, 2015 6:02 pm Post subject: Stratux Build |
On 11/12/2015 7:55 PM, Justin Jones wrote:
| Quote: | For those of you looking for an inexpensive solution for an ADS-B in (with AHRS if desired), this appears to be a relatively easy project. I am going to tackle it early next month.
It is very easy. I gathered the parts together and assembled it inside
a 3D printed case during one of our EAA meetings.
I had a chance to fly with it a couple of weeks ago, and the
iPad/Stratux/WingX combination saw the same ADS-B traffic as the
SkyRadar/GRT-HX combination.
There is a beginners guide here:
The 3D case files can be found at:
http://www.thingiverse.com/thing:1019324
-Dj
Dj Merrill - N1JOV - EAA Chapter 87
Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Glastar Flyer N866RH - http://deej.net/glastar/
schmoboy
Posted: Fri Nov 13, 2015 3:00 pm Post subject: Stratux Build |
makerxyz was ~$130.00 for the single band case in nylon. I'm sure the
dual would be more.
3dhubs didn't find anything cheaper than ~$180.00 for the single case in
nylon.
Planned on nylon for better heat tolerance, which bumps up the price.
What material did you have it printed in?
-Sean
| Quote: | Dj Merrill <mailto:deej(at)deej.net>
November 13, 2015 at 3:17 PM
Plenty of places that will do that for you.
The first is http://www.makexyz.com/
You upload your files to the website, and they will give you a quote.
The 2 part case I posted is about $50 from them, including shipping.
The second is sort of a broker service. You upload your files, and get
to choose from a bunch of places:
http://www.3dhubs.com
I'm sure there are other options.
-Dj
Posted: Fri Nov 13, 2015 6:09 pm Post subject: Stratux Build |
On 11/13/2015 5:57 PM, Sean Stephens wrote:
| Quote: | Planned on nylon for better heat tolerance, which bumps up the price.
ABS plastic. 3dhubs was something like $35.
-Dj
