michael(at)sausen.net Guest
Posted: Fri Nov 13, 2015 1:11 pm Post subject: AeroElectric-List: Stratux Build |
I'll second what DJ said. I've been messing around with it for the last couple months and being near the FAF for 18R at DFW, I see plenty of traffic. Now I just need to find someone to print a case for me.
Michael
deej(at)deej.net Guest
Posted: Fri Nov 13, 2015 1:20 pm Post subject: AeroElectric-List: Stratux Build |
On 11/13/2015 04:07 PM, Michael Sausen wrote:
| Quote: | Now I just need to find someone to print a case for me.
Plenty of places that will do that for you.
The first is http://www.makexyz.com/
You upload your files to the website, and they will give you a quote.
The 2 part case I posted is about $50 from them, including shipping.
The second is sort of a broker service. You upload your files, and get
to choose from a bunch of places:
http://www.3dhubs.com
I'm sure there are other options.
-Dj
Dj Merrill - N1JOV - EAA Chapter 87
Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Glastar Flyer N866RH - http://deej.net/glastar/
rv10flyer(at)live.com Guest
Posted: Fri Nov 13, 2015 1:52 pm Post subject: AeroElectric-List: Stratux Build |
Unless you're going dual, you don’t need a case. It comes with it, if not
there should be an extender to make it work. That may be easier than
building a new case?
I just need to figure out how to get it to work on FlightPlanGO. It
supposedly does already, just nothing explaining how?
Posted: Fri Nov 13, 2015 2:12 pm Post subject: AeroElectric-List: Stratux Build |
On 11/13/2015 4:49 PM, Pascal wrote:
| Quote: | Unless you're going dual, you don’t need a case. It comes with it, if
not there should be an extender to make it work. That may be easier than
The Stratux DIY project does not come with a case, you have to either
make something or buy something.
Too many parts and wires not to put all the various pieces inside
something, plus the case holds the antennas properly.
Search the term "stratux" on http://www.thingiverse.com for options,
including a case for the single band version.
For the very tiny cost increase, I can't imagine why one wouldn't build
the dual band version.
-Dj
Posted: Fri Nov 13, 2015 2:28 pm Post subject: AeroElectric-List: Stratux Build |
I was referring to the link for the starter kit
(http://www.amazon.com/dp/B00MV6TAJI/ref=cm_sw_su_dp) Raspberry Pi 2 +
Edimax WiFi + Preloaded 8GB SD Card + Case + Power
Yes in the case of the Dual case- one may need to replace the case with one
that works for 2 USB next/top of each other.
Posted: Fri Nov 13, 2015 2:41 pm Post subject: AeroElectric-List: Stratux Build |
On 11/13/2015 5:24 PM, Pascal wrote:
one that works for 2 USB next/top of each other.
Ah! That case is just for the Raspberry Pi, and doesn't enclose any of
the other parts of the Stratux system (GPS, Antennas, various wiring, etc).
-Dj
Posted: Sat Nov 14, 2015 9:37 am Post subject: AeroElectric-List: Stratux Build |
I have FltplanGo, and there is the option to add a custom ADS-B. I just don’t
know what the "port" would be. How did you get it configured on the WingX?
Thx
Posted: Sat Nov 14, 2015 9:48 am Post subject: AeroElectric-List: Stratux Build |
On 11/14/2015 12:34 PM, Pascal wrote:
| Quote: | How did you get it configured on the WingX?
The Stratux creates a private wireless network. On the iPad, all you
have to do is go to the wireless settings and join the "stratux"
wireless network. WingX then sees the ADS-B receiver and "just works".
-Dj
