Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27401 Location: Livermore CA USA
Posted: Tue Nov 17, 2015 7:26 pm Post subject: Lycoming Engine Fuel Flow Problem... |
Dear Listers,
I flew the RV-6 tonight that has a 1660 hour Lycoming O-360A1A with a Hartzell CS prop. I flew it 7 hours over a 3-day period about a week and a half ago with no issues whatsoever. Tonight, on take off, the EGT's all climbed into the 1450's right after take off and the CHT's were in the 400-450 range. The mixture was full rich. The engine didn't seem to be underpowered or rough but the fuel flow was about 9-10 GPH when it should have been in the 17-19GPH range. On the downwind I tried fiddling with the mixture with no change in making it richer. The mixture did make it leaner. I switched from the right to the left fuel tanks with no change. I have two fuel flow transducers one feeding the Skyview and the other feeding a Matronics FuelChec DX. Both were reading similarly low fuel flows at full throttle - 9-10gph. I didn't think to flip on the electric boost pump. But the flow definitely seemed restricted. The mixture control seems to have normal throw in and out and isn't binding and does lean the engine. I came in and landed with no issues.
I haven't pulled the cowling yet to have a look to see if its something obvious with the mixture cable, but what are some thoughts on what this could be?
Mechanical Fuel Pump?
Something in the Carb?
Plugged fuel line?
Thanks for your feedback,
Matt
RV-8 #82880 N998RV "Ruby Vixen"
http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log
http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log
Status: 260+ Hours TTSN - Version 2.0 Now Flying!
RV-6 #20916 N360EM "The Flyer"
http://www.mattsrv6.com - Matt's RV-6 Revitalization Log
Status: 350+ Hours - Full Flyer Mode!
Matt's Livermore Airport Live ATC Stream!
Check out the live ATC stream directly from my hangar at the Livermore
Airport. Includes both Tower and Ground transmissions. Archives too!
For entertainment purposes only. http://klvk.matronics.com
_________________ Matt Dralle
Posted: Tue Nov 17, 2015 7:27 pm Post subject: Lycoming Engine Fuel Flow Problem... |
Dear Listers,
Plugged fuel line?
Matt
Kellym
Posted: Tue Nov 17, 2015 8:10 pm Post subject: Lycoming Engine Fuel Flow Problem... |
You are correct. The FF is too low and it is reflected on the EGT and
CHT. In fact, you undoubtedly were LOP, producing about 140-150hp. A bit
surprising if it in fact still has a carburetor.
IMHO, if EGT goes above 1350 on takeoff roll, it is cause to abort if
feasible. It should be between 1200 and 1300, assuming sea level vicinity.
Plugged fuel filter, failing mechanical pump diaphram, carb fuel inlet
needle valve stuck, carb fuel vent plugged are all potential causes. If
there is any seepage on the mech pump drain, the diaphram is bad and not
generating the fuel pressure needed. The carb may or maynot have an
inlet screen that could be partially plugged. If the data goes back far
enough I would download the log from the Skyview and look for when the
problem first occurred. That may help you isolate when/where it happened
and what changed.
On 11/17/2015 8:24 PM, Matt Dralle wrote:
Dear Listers,
I flew the RV-6 tonight that has a 1660 hour Lycoming O-360A1A with a Hartzell CS prop. I flew it 7 hours over a 3-day period about a week and a half ago with no issues whatsoever. Tonight, on take off, the EGT's all climbed into the 1450's right after take off and the CHT's were in the 400-450 range. The mixture was full rich. The engine didn't seem to be underpowered or rough but the fuel flow was about 9-10 GPH when it should have been in the 17-19GPH range. On the downwind I tried fiddling with the mixture with no change in making it richer. The mixture did make it leaner. I switched from the right to the left fuel tanks with no change. I have two fuel flow transducers one feeding the Skyview and the other feeding a Matronics FuelChec DX. Both were reading similarly low fuel flows at full throttle - 9-10gph. I didn't think to flip on the electric boost pump. But the flow definitely seemed restricted. The mixture control seems to have normal throw in and out a!
Plugged fuel line?
Matt
KCHD |
Sounds like you have a blockage in your fuel filters that just barely allows enough fuel to flow.....
I had a similar issue with my AFP injected IO360B1F6. There is a small fuel inlet filter that was clogged with fine black goo. Cleaned that and added a larger capacity filter upstream that has a smaller micron rating than the inlet filter - it is on my annual list now.
Cured the issue for me.
Glad you had enough fuel flow to continue flying and safely land. Throttling back helped me - I didn't experience mine on take off though.....boost pump didn't help me....
vanremog(at)aol.com Guest
Posted: Tue Nov 17, 2015 10:49 pm Post subject: Lycoming Engine Fuel Flow Problem... |
Have you cleaned all your screens?
Did you switch tanks?
Did you check your vents?
-GV
Sent from a galaxy far far away...
Matt Dralle <dralle(at)matronics.com> wrote:
--> RV-List message posted by: Matt Dralle <dralle(at)matronics.com>
Dear Listers,
Plugged fuel line?
Matt
_-============================================================
_-=
_-= -- Please Support Your Lists This Month --
_-= (And Get Some AWESOME FREE Gifts!)
_-=
_-= November is the Annual List Fund Raiser. Click on
_-= the Contribution link below to find out more about
_-= this year's Terrific Free Incentive Gifts provided
_-= by:
_-=
_-= * The Builder's Bookstore www.buildersbooks.com
_-=
_-= List Contribution Web Site:
_-=
_-= --> http://www.matronics.com/contribution
_-=
_-= Thank you for your generous support!
_-=
_-= -Matt Dralle, List Admin.
_-=
_-= - The RV-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
_-= Photoshare, and much much more:
_-=
_-= --> http://www.matronics.com/Navigator?RV-List
_-=
_-= - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-= --> http://forums.matronics.com
_-=
_-= - List Contribution Web Site -
n146wb(at)cfu.net Guest
Posted: Wed Nov 18, 2015 5:04 am Post subject: Lycoming Engine Fuel Flow Problem... |
Admittedly, with all the readings on your monitoring giving abnormal numbers, it appears to be be a problem with the fuel system, but I would first check to see that the problem is real. Do you know what the engine pulled for static rpm, wot on the ground before the problem showed up? If so, then I would check the wot rpm now to see if you are getting full power. Did you fly long enough to check your real fuel usage by refueling and comparing usage against what you would normally expect? If you seem to get full rpm (power) and real fuel usage is normal then there MIGHT be an electrical problem that's affecting your monitoring system, like a bad ground.
Warren
denis.walsh(at)comcast.ne Guest
Posted: Wed Nov 18, 2015 8:39 am Post subject: Lycoming Engine Fuel Flow Problem... |
I have a similar set up with an A1A. Your observations and deductions seem logical to me. I would do the easiest thing first, and check the boost pump on to see if it brings up the flow/pressure. This would point to the mechanical pump as a problem.
By the way, it is my opinion that you should always take off with the boost pump on. I also use a procedure by which I check the boost pump for pressure before engine start, then start with only the mechanical pump. When the run up is complete, Then I turn on the boost pump for take off. Again this is another chance to catch a failed or failing mech pump before take off.
Hope this helps.
Denis Walsh
denis.walsh(at)comcast.net
| Quote: | On 17Nov, 2015, at 20:24, Matt Dralle <dralle(at)matronics.com> wrote:
Dear Listers,
Plugged fuel line?
Matt
Posted: Wed Nov 18, 2015 10:23 am Post subject: Lycoming Engine Fuel Flow Problem... |
Denis,
I use your method for take-offs also!
Ralph
Posted: Wed Nov 18, 2015 11:40 am Post subject: Lycoming Engine Fuel Flow Problem... |
I switched tanks with no change in flow. So it would seem to not to be related to the fuel tanks or their plumbing specifically. I'm anxious to dig in and figure out what's going on...
Matt
At 10:48 PM 11/17/2015 Tuesday, you wrote:
| Quote: | Have you cleaned all your screens?
-GV
Dear Listers,
| Quote: | nd isn't binding and does lean the engine. I came in and landed with no issues.
Plugged fuel line?
Matt
Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550
