millner(at)me.com Guest
				 Posted: Tue Nov 24, 2015 5:14 pm    Post subject: Troubleshooting radio whine/noise on Cessna  182P |
				Charlie,
      The problem is that you're not aware of how Cessna wired the     regulator in this 182...
      Instead of the OV relay interrupting the current path between the     regulator and the field terminal as you propose OBAM folks usually     do it, the OV relay and the alternator half of the master switch     interrupt the power supply *to* the regulator, via the S or Supply     terminal.
      However... the automotive version supplies the regulator and     alternator from both the S and the A terminal... and once the master     is on, the A terminal is hot... so the Cessna OV relay and     alternator half of the master switch are irrelevant.
      So... an automotive regulator in the Cessna wiring diagram? The     alternator is non-controllable... which could be a bad thing.
      See attached wiring diagram.
      Paul
      http://www.secure4host.net/upload/files/Cessna_Alternator_Wiring.pdf
      On 11/24/2015 11:18 AM, Charlie England       wrote:
       	  | Quote: | 	 		  You do       NOT want a Ford automotive regulator... it can cause an       overvoltage situation that even an external OV relay cannot       overcome (the automotive regulator sources regulator power       directly from the alternator, and thus ignores whether the OV       relay or alternator half of the master switch are providing power,       or not.)
        I can't make sense of this, as long as we're talking about an       externally regulated alternator. Ford style regulators are flying       in thousands of homebuilts safely (assuming that OV protection is       used). As long as the wire to the field is interrupted, the       alternator cannot produce power. Typical OV protection circuits       either open the field lead or 'crowbar' it to ground, tripping the       field circuit breaker (which breaks the field circuit). Either       way, there's no way for the regulator to keep the alternator       operating.
