		jrevens
				 Posted: Thu Nov 19, 2015 7:12 pm    Post subject: Rotax ignition wiring |
				This may be a dumb question, but would using a shielded twisted pair for the combined ignition control wiring to both modules be OK, or are 2 individual shielded single conductor wires preferred for some reason?  I am basically using Bob's Z-16 diagram... I am very grateful to have that, Bob!
  _________________ John Evens
Thorp T-18 N71JE (sold)
Kitfox SS7 N27JE (built & flying) |
		user9253
  Joined: 28 Mar 2008 Posts: 1944 Location: Riley TWP Michigan
				 Posted: Thu Nov 19, 2015 7:46 pm    Post subject: Re: Rotax ignition wiring |
				It is better to have individual wires for each ignition to prevent one electrical problem from disabling both ignitions.  The shield on each ignition wire (on my Rotax powered RV-12) is separated in the middle.  The shield is grounded at each end.  I suspect that Van's designed it that way to prevent starter current from burning open the shield if the engine ground wire ever breaks.
  _________________ Joe Gores |
				 Posted: Fri Nov 20, 2015 5:53 am    Post subject: Rotax ignition wiring |
				At 09:12 PM 11/19/2015, you wrote:
   	  | Quote: | 	 		  --> AeroElectric-List message posted by: "jrevens" <jrevens(at)comcast.net>
  This may be a dumb question, but would using a shielded twisted pair for the combined ignition control wiring to both modules be OK, or are 2 individual shielded single conductor wires preferred for some reason?  I am basically using Bob's Z-16 diagram... I am very grateful to have that, Bob! |
    My pleasure. What you propose would be fine.
    Do you already have some twisted pair 20 or
    18AWG?
				 Posted: Fri Nov 20, 2015 5:55 am    Post subject: Rotax ignition wiring |
				At 09:46 PM 11/19/2015, you wrote:
   	  | Quote: | 	 		  --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com>
  It is better to have individual wires for each ignition to prevent one electrical problem from disabling both ignitions.  The shield on each ignition wire (on my Rotax powered RV-12) is separated in the middle.  The shield is grounded at each end.  I suspect that Van's designed it that way to prevent starter current from burning open the shield if the engine ground wire ever breaks. |
     Interesting . . . not sure I understand
     why that would be 'better' . . . I like
     to see the designer's white paper on the
     thought process.
		rickofudall
				 Posted: Fri Nov 20, 2015 5:06 pm    Post subject: Rotax ignition wiring |
				All, The ignition modules and the pickups together cost almost $4,000 to replace. A few feet of shielded wire costs what, $1.49? I'd wire it exactly as Rotax says rather than experiment.
 Rick Girard
 On Fri, Nov 20, 2015 at 7:53 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
  	  | Quote: | 	 		    At 09:46 PM 11/19/2015, you wrote:
   	  | Quote: | 	 		  --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)>
     thought process.
 “Blessed are the cracked, for they shall let in the light.”   Groucho Marx
		jrevens
				 Posted: Sat Nov 21, 2015 12:46 pm    Post subject: Re: Rotax ignition wiring |
				 	  | nuckolls.bob(at)aeroelect wrote: | 	 		  At 09:12 PM 11/19/2015, you wrote:
   	  | Quote: | 	 		  --> AeroElectric-List message posted by: "jrevens" <jrevens>
    18AWG?
    Bob . . . |
 Yes I do, Bob. Not sure if I'll use it, but I was just trying to educate myself a little further in analyzing if there were any issues with using 2 wires enclosed in a common shield for this application. I like your suggestion to ground at the engine only and use the shield for the conductor back to the module.
 Thanks to all for the replies.
		jrevens
				 Posted: Sat Nov 21, 2015 1:08 pm    Post subject: Re: Rotax ignition wiring |
				 	  | rickofudall wrote: | 	 		  All, The ignition modules and the pickups together cost almost $4,000 to replace. A few feet of shielded wire costs what, $1.49? I'd wire it exactly as Rotax says rather than experiment.
 Rick Girard |
 Yep, those modules and pickups are really stupidly expensive and over-priced. I'm amazed that someone hasn't come up with a viable aftermarket replacement that could probably be sold for a fraction of the price and still make a nice profit.
 I'm really not trying to "experiment" with this, Rick, but sometimes there is a little more elegant or simple way to do something that accomplishes the same result... maybe resulting in less weight, fewer connections, better design from a "noise" standpoint, etc. I'm not really convinced that doing everything "exactly as Rotax says..." is always the best that I can do. I've seen a couple of possible errors in their manuals for the 912 series engines. For instance, yesterday while studying the latest 912 Installation manual, I noticed the following on p.4 of section 80-00-00 regarding the starter system - "NOTICE - The starter relay must be isolated from the aircraft ground". What? I'm not sure if I'm misunderstanding that or what.
		jrevens
				 Posted: Tue Nov 24, 2015 10:38 pm    Post subject: Re: Rotax ignition wiring |
				Since there seem to be quite a few Rotax users on this forum, I have another question... is it really necessary to separate the wiring coming from the engine (pressure & temperature sensors, tachometer signal, etc). from the ignition (so called "p-leads") wires when penetrating the firewall. In other words, should the ignition wires have their own penetration, separated from that other wiring? I believe this is what Kitfox recommends. I hope this specific subject hasn't already been discussed on this forum.
		user9253
				 Posted: Wed Nov 25, 2015 6:34 am    Post subject: Re: Rotax ignition wiring |
				 	  | Quote: | 	 		  | is it really necessary to separate the wiring coming from the engine |
 I have a Van's RV-12 registered as an E-LSA.  An E-LSA must be built exactly per the plans using only parts purchased from the manufacturer.  There are about 500 RV-12s flying with the Rotax 912.  All engine wires, including ignition, pass through one grommet in the firewall.
		ceengland7(at)gmail.com Guest
				 Posted: Wed Nov 25, 2015 7:14 am    Post subject: Rotax ignition wiring |
				On 11/25/2015 12:38 AM, jrevens wrote:
  Since there seem to be quite a few Rotax users on this forum, I have another question... is it really necessary to separate the wiring coming from the engine (pressure & temperature sensors, tachometer signal, etc). from the ignition wires when penetrating the firewall. In other words, should the ignition wire have their own penetration, separated from that other wiring? I believe this is what Kitfox recommends. I hope this specific subject hasn't already been discussed on this forum.
  John Evens
  Thorp T-18 N71JE (built & flying)
  Kitfox SS7 N27JE (building)
 I can't directly address the Rotax question, but 'normal' practice when
 wires must be near each other that may hav interference issues is to
 have them cross at as close to 90 degrees as possible. The longer the
 parallel run, the more likely the interference. Might be worth a try to
 bundle the noise makers separate from the sensors, and try to make an
 'X' at the FW passthrough.
 Charlie
		rv10pro(at)gmail.com Guest
				 Posted: Wed Nov 25, 2015 8:22 am    Post subject: Rotax ignition wiring |
				Does this imply Van's would discourage buying a second pass - thru from them  and separating ignition wires from lower voltage signal wires.  What does Dynon say?
 Van's has always supported Safety of Flight issues to the best of my knowledge.
 John Cox On Nov 25, 2015 06:43, "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)> wrote: 	  | Quote: | 	 		  --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)>
  Joe Gores
  http://forums.matronics.com/viewtopic.php?p=450208#450208
  br> fts!)
  r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
            -Matt Dralle, List Admin.
   FORUMS -
  b Site -
		user9253
				 Posted: Wed Nov 25, 2015 8:59 am    Post subject: Re: Rotax ignition wiring |
				 	  | Quote: | 	 		  | Does this imply Van's would discourage buying a second pass - thru from them  and separating ignition wires from lower voltage signal wires. |
 Van's will sell whatever a customer wants to buy.  Van's does discourage making changes to their designs.  USA government regulations require that aircraft registered as E-LSA be built exactly per the plans.  If a builder wanted to install two grommets for wires passing through the firewall, then the aircraft would have to be registered as E-AB, not E-LSA.  The majority of RV-12 are registered as E-LSA and are built according to the plans.  The point that I was trying to make is that it is OK to bundle all Rotax engine wires together because hundreds of RV-12s are flying with no electrical interference problems.  The Rotax has electronic ignition, not magnetos.  The Rotax ignition control circuit might not be high voltage like magneto control circuits.  I do not know.
				 Posted: Wed Nov 25, 2015 9:24 am    Post subject: Rotax ignition wiring |
				Get with your intended DAR and ask about your "Must" understanding.  You might be pleasantly surprised with a safety improvement to boot.  I don't see the second pass-thru as a deal killer.
 John Cox On Nov 25, 2015 09:08, "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)> wrote: 	  | Quote: | 	 		  --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)>
  Joe Gores
  http://forums.matronics.com/viewtopic.php?p=450212#450212
  br> fts!)
   FORUMS -
  b Site -
				 Posted: Wed Nov 25, 2015 9:26 am    Post subject: Rotax ignition wiring |
				Once certificated E-LSA I would wager the modification would not invalidate your airworthiness and Not trigger a new Phase One.
  Joe Gores
  br> fts!)
   FORUMS -
  b Site -
		user9253
				 Posted: Wed Nov 25, 2015 10:06 am    Post subject: Re: Rotax ignition wiring |
				What safety improvement is achieved by drilling another hole through the firewall?
		richard.beebe(at)yale.edu Guest
				 Posted: Wed Nov 25, 2015 10:36 am    Post subject: Rotax ignition wiring |
				Joe is correct that an E-LSA must be built exactly according to factory
 plans. However, once that's done it can be modified by the owner. If
 you're building the plane you can ask Vans if they would approve a
 second pass-thru. If so, then you can add it. If not, then you have to
 wait until after the plane is certified.
 Vans is pretty safety conscious so I agree that if they don't have a
 problem running all the wires through a single pass-thru then I probably
 wouldn't either.
 --Rick
 On 11/25/2015 12:24 PM, John Cox wrote:
  	  | Quote: | 	 		   Once certificated E-LSA I would wager the modification would not
  John Cox
  <mailto:fransew(at)gmail.com>> wrote:
      <fransew(at)gmail.com <mailto:fransew(at)gmail.com>>
      signal wires.
      Joe Gores
		gerry.vandyk(at)eastlink. Guest
				 Posted: Wed Nov 25, 2015 10:54 am    Post subject: Rotax ignition wiring |
				Have the rules for ELSA changed?  My understanding was, while a SLSA
 must conform to the manufacturer's specs throughout its life, after an
 ELSA has been registered and the test flying restrictions lifted, the
 owner is free to modify their ELSA as he sees fit, but it must continue
 to comply with LSA rules.
 I reference these paragraphs from Kitplanes March 2012 "Understanding
 Experimental Light Sport Aircraft" by Dave Martin.  (The last 5
 paragraphs of the article.
 "I've already alluded to an FAA ruling that makes it legal for the
 builder of an ELSA to make changes. In the case of a kit such as the
 RV-12, any change that does not take the aircraft outside of the LSA
 definition may be made as soon as the pink airworthiness certificate is
 signed by the FAA's inspector, usually a DAR. Mel Asberry, who writes
 the "Ask the DAR" column for this magazine, confirms the FAA's point
 that this feature has been in the plan from the beginning. Its rationale
 is that ELSA come under the same rules as any other
 Experimental-category aircraft.
 "Some of us, myself included, missed this detail in our understanding of
 ELSA rules, and I found it to be a jaw-dropper. That's because no other
 Experimental-category aircraft is like a factory-approved ELSA. If I had
 built my RV-12 as an EAB, I could have modified it however I desired
 during construction. But as an ELSA, mine was required to be built
 initially exactly like the SLSA prototype.
 "In addition to building, all testing was exactly as specified by Van's
 Aircraft. On the first five flights, I flew as a production test pilot,
 not as an experimental test pilot as I would in a new EAB. Also, if I
 had built the RV-12 as an EAB, the builder block on the data plate could
 read "Martin RV-12." Because my shop was a subset of the kit factory, my
 data plate lists Van's Aircraft Company as the builder.
 "The result of this provision is that I could now change my airplane
 enough to cause it to operate quite differently—as long as it remains
 within the LSA definition. It's almost as if Piper and Cessna owners
 were allowed to make any changes they wanted.
 "So this provision of ELSA remains, and it may explain the lack of ELSA
 kits competing with the Van's RV-12. Why should a company take on the
 additional liability of a customer making changes that are neither
 authorized nor tested by the factory?"
 Gerry van Dyk
		user9253
				 Posted: Wed Nov 25, 2015 3:44 pm    Post subject: Re: Rotax ignition wiring |
				 	  | Quote: | 	 		  | Have the rules for ELSA changed? |
 No, the rules have not changed and your understanding is correct.  Some builders have made modifications to their E-LSA RV-12 after certification.  And Van's has even adopted some of those mods.
   The originator of this thread asked if it is OK to bundle all engine wires together in his Rotax powered Kitfox.  I replied "yes" because that is the way that Van's designed the RV-12, which has the same engine.  If it is explained why bundling all engine wires together is unsafe, then I will change my wiring.
   I do not think that the Kitfox can be registered as an E-LSA.  So the Kitfox builder can wire his plane however he thinks is best.
				 Posted: Wed Nov 25, 2015 10:38 pm    Post subject: Rotax ignition wiring |
				The discussion point should center around "any" advantage of not bundling as a single penetration thru the firewall and the enhancements within E-LSA and the latitude if any to modify within the allowance by the chosen DAR.
 There are many DARs.  I have seen mods.  They make sense... In some cases.  That is what is great about Amateur built.  Happy Holidays!
 John Cox On Nov 25, 2015 15:50, "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)> wrote: 	  | Quote: | 	 		  --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)>
  Joe Gores
  http://forums.matronics.com/viewtopic.php?p=450301#450301
  br> fts!)
   FORUMS -
  b Site -
		user9253
				 Posted: Thu Nov 26, 2015 6:33 am    Post subject: Re: Rotax ignition wiring |
				Happy Thanksgiving !
