rickofudall
Posted: Thu Nov 26, 2015 1:13 pm Post subject: New camera mount |
It's not for a Kolb but for my trike. Because of the changing angle of the wing I wanted adjustment in three dimensions. When I went through my strategic supplies I found two pieces of channel that nested together with just enough room for an AN960-816L washer on each side between them. Thanks to the Yard Store the total cost of the mount was about a buck.When I bolted it to the wing strut I used an eye bolt so I'd have a second safety strap in case the bolt to the camera base and the straps from the camera's strap lugs to the mount both failed.
Rick Girard
“Blessed are the cracked, for they shall let in the light.” Groucho Marx
271.99 KB |
1178 Time(s) |
70.92 KB |
1178 Time(s) |
