wladimirkummer(at)gmail.c Guest
Posted: Wed Dec 09, 2015 2:56 am Post subject: Interior finishing |
Hi fellows,
I´m about to attach the top fuse but first considering do some interior
finish work to the cockpit. In your opinion what would be the lightest
finish?
Best
Wladimir
To be Europa XS MG kit A193
Fred Klein
Posted: Wed Dec 09, 2015 7:30 am Post subject: Interior finishing |
| Quote: | On Dec 9, 2015, at 2:52 AM, Wladimir Kummer de Paula <wladimirkummer(at)gmail.com (wladimirkummer(at)gmail.com)> wrote:
I´m about to attach the top fuse but first considering do some interiorfinish work to the cockpit. In your opinion what would be the lightestfinish?
Wladimir…I used a “splatter paint” called Zolotone, sprayed on w/ an oversize needle in the gun. I found it to be a wonderful material which blends easily. I also am happy to have sprayed the interior of the top fuselage before bonding it to the lower fuselage, believing that I’ve saved myself a lot of awkward effort…Good luck, Fred
paul.the.aviator(at)gmail Guest
Posted: Wed Dec 09, 2015 11:10 am Post subject: Interior finishing |
The only thing I can add on Zolotone is to prepare your surface well and then spray it with clear coat to protect it. I did put some upholstery in my airplane in areas of high wear, for example the baggage compartment.
On Wed, Dec 9, 2015 at 9:26 AM, Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)> wrote:
I´m about to attach the top fuse but first considering do some interiorfinish work to the cockpit. In your opinion what would be the lightestfinish?Â
budyerly(at)msn.com Guest
Posted: Sun Dec 13, 2015 1:15 pm Post subject: Interior finishing |
To add to Fred’s comment on the importance of interior finish prep.
Painting requires tedious prep for sure. Clean well and smooth as much as you can while preparing yourself for some awkward sanding. For your lungs sake, use a good respirator.
Let me emphasize that Zolotone or trunk paint is forgiving but will scrape off with wear so a good polyurethane clear flat over the interior adds wear resistance and is easier to clean. Heavy truck bed liner paint wears well, but is heavier than fabric and some leathers.
As far as the doors go we paint the interior door the same color as the exterior although it can be painted to match the interior.
Notes on interior weight.
Interior fabrics:
Pay attention to your seat cushions. I chose medium weight foam rather than soft or memory foam. That’s a personal choice. 2.5 pound medium foam works for my 190 pounds.
I use 2 inch on the seat bottom and 1 inch for the seat back and a back bolster of about another three inches total thickness on average at the small of the back.
Cut the foam to size and sit in the seat for two hours minimum. I make my upholsterer make the cushions to shape, add a small side bolster, then I, or preferably the customer sits in the seat for a couple hours (normally programming his instrument EFIS and Engine monitor) and get feedback on what he needs before final sewing. Do not forget the back cushion. The back cushion should include a proper sitting angle and back lumbar support for the shape of your back. Both seat cushions upholstered should not exceed 10 pounds.
Ready to install cushions are fine, however look at the weight. Oregon Aero has very nice cushions but they are very heavy.
Leather is normally milled about 3/32 inch thick and a half a hide costs $500. Half a hide will do the cushions and center console. Weight is about 2.5 oz per square foot.
Upholstery fabric varies and is about the same weight if it has foam bonded to it. I use tweed for the sides and tweed with leather accents for the center and high wear areas.
I like a leather cushion as it is easier to slide in and out of the aircraft.
Overhead fabric is a pain for anybody and adds the most time to the project. Mine is a $90 a yard material and is very light. I got it for a steal at $10 a yard. Most auto shops have a nice selection of vinyl and or what is called “Mouse Fur” fabric which is easy to work with and fairly cheap at $3 a yard. Vinyl on the overhead tends to fall off over time because the normal interior glues have trouble holding up the weight. Mouse Fur is quite light and is easy to glue with proper contact adhesives (3M 777 is pretty good).
Carpet is really heavy. I bought the lightest I could find. It weighs about 1 pound per square yard. It is not high wear.
Total weight of my interior was about 20 pounds including the carpet, seat bottom fabric coated and a complete baggage bay covering with embroidery.
Both of my go to upholsterers have increased their prices to $90 per hour and estimate about 200 hours to do the plane and actually take 250. My last bid was $6000 for a leather and full custom upholstered interior with embroidery (it used to cost $4000 max). (We do a seat back embroidery if the customer wants it, but usually only do EXPERIMENTAL across the D panel in the rear).
Make sure all your fabrics are cleanable. That is why I do not embroider my seat back. Easier to clean and slide down.
Frankly the Europa-Aircraft tri gear interior kit price is pretty fair at 1000 UK pounds or $1600 US for a sewn kit with embroidery on the cushions. Then Zolatone the top and find someone to install it.
Shipping is a fairly high cost. Expect it to cost nearly $400 to pack and ship.
An auto upholstery shop may bid the install cheap, because it looks small, but they usually don’t want to ever do one again. Spend time with the upholsterer and visit often. You don’t want to end up with a screw or snap in your fuel tank. Its happened.
Just my thoughts,
Bud Yerly
Sent: Wednesday, December 09, 2015 10:26 AM
To: europa-list(at)matronics.com (europa-list(at)matronics.com)
Subject: Re: Interior finishing
