Transponder and Radio coax interference
wdaniell.longport(at)gmai
PostPosted: Mon Dec 14, 2015 9:31 am    Post subject: Transponder and Radio coax interference Reply with quote
Can the transponder and the Radio coax share the same routing?
In other words different coax cables obviously but will they interfere with each other if they are routed together ...for example under the LH door sill in close proximity?
I have routed all electrical wiring under the RH door sill.
Many thanks
Will
William Daniell
LONGPORT
+57 310 295 0744
Burrilla
PostPosted: Mon Dec 14, 2015 9:41 am    Post subject: Transponder and Radio coax interference Reply with quote
No reason why not - mine are.
The frequencies are so far apart that any leakage of RF is going to be negligible and no effect.
Alan
#0303
On 14 Dec 2015, at 17:30, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
Many thanks
Will
William Daniell
LONGPORT+57 310 295 0744
PostPosted: Mon Dec 14, 2015 9:56 am    Post subject: Transponder and Radio coax interference Reply with quote
Excellent thanks
William Daniell
LONGPORT
+57 310 295 0744
On Mon, Dec 14, 2015 at 12:40 PM, Alan Burrill <alanb(at)dpy01.co.uk (alanb(at)dpy01.co.uk)> wrote:
Alan
#0303
Many thanks
Will
William Daniell
LONGPORT
+57 310 295 0744
