		sam.marlow
				 Posted: Sat Dec 19, 2015 6:49 am    Post subject: Oscilloscope for Android Phone |
				Has anyone heard of or have any experience with one? I have noise in my
 system somewhere, that is throwing off my EFIS and A/P systems.
		rlborger(at)mac.com Guest
				 Posted: Sat Dec 19, 2015 7:22 am    Post subject: Oscilloscope for Android Phone |
				Sam,
 I’m not exactly sure what your question is.
 Do you believe your phone is causing the offending noise?
 If so, do you have a plug-in USB charger for your phone installed in your aircraft?
 Blue skies & tailwinds,
 Bob Borger
 Europa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs).
 Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
 3705 Lynchburg Dr.
 Corinth, TX  76208-5331
 Cel: 817-992-1117
 rlborger(at)mac.com
 On Dec 19, 2015, at 8:35 AM, Sam Marlow <sam.marlow(at)roadrunner.com> wrote:
 Has anyone heard of or have any experience with one? I have noise in my system somewhere, that is throwing off my EFIS and A/P systems.
		ron228rj(at)gmail.com Guest
				 Posted: Sat Dec 19, 2015 7:38 am    Post subject: Oscilloscope for Android Phone |
				He is talking about an app to turn a phone into an oscilloscope. I believe that requires voltage probe to look at electrical signals.
 Ron On Dec 19, 2015 10:28 AM, "Robert Borger" <rlborger(at)mac.com (rlborger(at)mac.com)> wrote: 	  | Quote: | 	 		  --> AeroElectric-List message posted by: Robert Borger <rlborger(at)mac.com (rlborger(at)mac.com)>
  Sam,
  Bob Borger
  3705 Lynchburg Dr.
  Cel: [url=tel:817-992-1117]817-992-1117[/url]
  On Dec 19, 2015, at 8:35 AM, Sam Marlow <sam.marlow(at)roadrunner.com (sam.marlow(at)roadrunner.com)> wrote:
  --> AeroElectric-List message posted by: Sam Marlow <sam.marlow(at)roadrunner.com (sam.marlow(at)roadrunner.com)>
  br> fts!)
  r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
            -Matt Dralle, List Admin.
   FORUMS -
  b Site -
		rampil
		jetboy
				 Posted: Sun Dec 20, 2015 3:08 pm    Post subject: Re: Oscilloscope for Android Phone |
				I have 2 apps which work moderately well,
 "audalyzer" and "simpleFFT"
 you will need to cut a headset cord or buy a connector to get the signals in
 there are 2 styles of connector pinout
 mine is Sony Ericson, the plug is trrs:
 tip - nc
 ring 1 -  a 1k ohm resistor connect to sleeve
 ring 2 - a 1.8 k ohm resistor to sleeve plus a 10 k ohm resistor and then  via a 0.1 uF capacitor to your probe
 sleeve - ground/shield of probe
 you dont really need the capacitor
 the purpose of the smaller resistors is to tell the phone what type of 'headset' is connected
 with these components, calibration is approximately reading in dBm on the audalyzer app for levels between 0 and -40 dBm
 there is another app "TestTone" if you want to generate a signal
 Ralph
  _________________ Ralph - CH701 / 2200a |
		rampil
				 Posted: Mon Dec 21, 2015 5:53 am    Post subject: Re: Oscilloscope for Android Phone |
				Hi All,
 Im not sure what signals Sam is looking for with his desire for an
 oscilloscope. There is no description of the interference with his EFIS
 and autopilot. Without some detailed sort of characterization of the
 symptoms you can't even guess what bandwidth you might need in a scope
 to track down the noise. Is it audio range, power inverter range, RF, etc?
 The android apps mentioned by Jetboy seen to be spectrum analyzers for
 audio range only, so far as I can tell, not oscilloscope apps.
 Sam: what wires are you planning to look at with a scope? Power?
 Digital I/O lines, analog I/O?  If you are thinking about splicing a headset
 cord on to a avionics power line, remember that 12 V will smoke an Android.
 Real scopes generally have voltage divider probes and and are usually
 tolerant of much wider voltage ranges to start with.
		sam.marlow
				 Posted: Wed Dec 23, 2015 7:48 am    Post subject: Oscilloscope for Android Phone |
				Thanks!
		sam.marlow
				 Posted: Wed Dec 23, 2015 8:03 am    Post subject: Oscilloscope for Android Phone |
				I tracked it down to a bad alternator, by the old, switch parts until
 you find it! Not ideal, but it worked......
 Thanks!
 rampil wrote:
  Hi All,
  Ira N224XS
  http://forums.matronics.com/viewtopic.php?p=451285#451285
