graeme bird
Posted: Thu Dec 24, 2015 10:49 am Post subject: CS10 removal; Mod 76 |
So all the instructions followed for CS10 removal but I cant see how it is going to come out. Seems like CS08 would need to come out. Quite a job undoing all the bolts. Also seem to have some mildew forming in the area for which I would tend to use bleach on but I dont want to introduce corrosion - any ideas on that?
_________________ Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk |
dpark748(at)icloud.com Guest
Posted: Thu Dec 24, 2015 11:26 am Post subject: CS10 removal; Mod 76 |
I am about to attack this job after Christmas and the instructions say it should clear the CS08?
Dave G-LDVO
| Quote: | On 24 Dec 2015, at 18:49, graeme bird <graeme(at)gdbmk.co.uk> wrote:
Graeme Bird
G-UMPY
Mono Classic/XS FFW 912S/Woodcomp 3000/3W
Newby: 200 hours 4 years on the Mono
g(at)gdbmk.co.uk
http://forums.matronics.com/viewtopic.php?p=451400#451400
rogersheridan(at)mac.com Guest
Posted: Thu Dec 24, 2015 1:12 pm Post subject: CS10 removal; Mod 76 |
The old mod 46 instructions apply and are slightly different.
You also need to disconnect the flap pushrod.
I’ll be impressed if you get that job done tomorrow!
Merry Xmas.
| Quote: | On 24 Dec 2015, at 19:25, david park <dpark748(at)icloud.com> wrote:
Dave G-LDVO
> Graeme Bird
> G-UMPY
> g(at)gdbmk.co.uk
graeme bird
Posted: Thu Dec 24, 2015 2:11 pm Post subject: Re: CS10 removal; Mod 76 |
mod 46 ? Can't find and info on that where could I find it?
Sounds like a good tip to disconnect the flap control.
Felt like a gynaecologist today working through a 4 x 5 " hole !
Took me from 11:30 to 5:00 to get all the nuts undone and out. That was on my own, another pair of hands would have helped a bit.
kit4 (Wagstaff) TBD
graeme bird
Posted: Thu Dec 24, 2015 2:29 pm Post subject: Re: CS10 removal; Mod 76 |
found mod 46 thanks.
[http://www.europaowners.org/main.php?g2_view=core.DownloadItem&g2_itemId=81847]
kit4 (Wagstaff) TBD
stranfaer(at)btinternet.c Guest
Posted: Fri Dec 25, 2015 3:13 am Post subject: CS10 removal; Mod 76 |
Graham bleach will kill the mildew but you are correct about possible corrosion you could try swimming pool algaecide it's a bit more gentle
I have some if you are near enough to me
Compliments of the season
The other one
David Joyce
Sent from the iPad of David Joyce
www.eastmidsspas.com
Graeme Bird
G-UMPY
g(at)gdbmk.co.uk
graeme bird
Posted: Sun Dec 27, 2015 12:59 pm Post subject: Re: CS10 removal; Mod 76 |
It came out. I just needed to remove the Port control stick to allow CS08 to move out the way. Set the wife on the cleaning and what I thought might be mildew just washed off. In retrospect, I didnt need to unlink the flap control or remove the starboard fuel tank spacer.
kit4 (Wagstaff) TBD
