vanremog(at)aol.com Guest
Posted: Tue Dec 22, 2015 2:17 pm Post subject: RV-List: Re: Lycoming O-360 Fuel Flow Rate |
It's just the engineer in me, but I always like to do post mortems with failed components. In the case of the pump, I would want to understand what in the pump caused the blockage or failure to pump per spec. In the case of the carb I would want to understand if the main jet, float, filter or ??? were hosed.
-GV
